Water Collected in Underbody Panel (Tranny panel)
Is collecting water here normal and likely due to the long trip with the AC on? Where are there drains or water lines above the tranny? In looking at the transmission itself, there were many white water evaporation marks on the casing that appeared fresh and surely not normal from a design standpoint. I?ve looked at the tranny a few times before and never notice this.
![Excl](https://5series.net/forums/images/smilies/imported/excl.gif)
You may not have read the section recommending cornering at very high speeds to discharge fluids collecting in the plastic, under-car, shields
Seriously, it's possible the Plastic AC condensate drain is misdirected and instead of dumping it under the car it's running into the plastic shields. AC systems can extract a ton of water - especially on hot humid days. I think if you locate that hose - I think it's somewhere behind the passenger front wheel well - and make sure it isn't dumping water into the belly pan you'll be off and running w/o needing to drill any drain holes in the plastic body shield.
My Ride: 2006 BMW 550i "Ben Hogan's 5 Iron"
SilverGrey/Black Sport, L7, NAV, CW, AS, Split FR
2003 Audi A4 3.0 CVT "Part of the Moniker"
Silver/Ebony, Prem, CW, Star 17s
Vman33
03-14-2022 04:43 AM
DetailersDomain
Detailing Forum
09-22-2015 03:59 PM
brooklynbmw
09-16-2015 01:41 PM
DetailersDomain
Detailing Forum
09-03-2015 07:08 PM
umnitza
09-02-2015 11:28 AM
