5Series.net - Forums
-   -   voltage (https://5series.net/forums/e60-discussion-2/voltage-149596/)
E54AHS Apr 16, 2019 03:34 AM
voltage
been told my alternator is OVER CHARGING guy took a plug off it saying its to do with smart charge? with wire on it was 15volts wire off its 14 volts he says alternator fkd but if its still charging how can it be fkd my freind says its possibility of a module instead of alternator anyone shed light on this good thing is no more warning lights appear on the dash
NoQuarter Apr 17, 2019 07:29 PM
Sorry dude... not enough info here to make any helpful ideas.
You need error codes or something more helpful. 14 some volts when engine running is normal.
E54AHS Apr 17, 2019 11:06 PM
its the voltage regulator on back of alternator thats faulty just need to replace it cheers mate
FormerE30Owner Apr 18, 2019 05:01 AM
From what you have described, one cannot definitely say that the voltage regulator is faulty. Nothing wrong with 15 volts charging the battery, depending on its state and type. And 14 volts resting is also normal. Sometimes "a little knowledge is a dangerous thing".
E54AHS Apr 19, 2019 05:18 AM
as soon as auto electrician disconnected the plug from regulator charging voltage was normal and not had any problems with the car thats 5days now so might keep fekn thing now 😎😁
https://cimg4.ibsrv.net/gimg/5series...328d60cf41.jpg
GreaseMonkey535i Apr 19, 2019 06:14 AM
its the voltage regulator. common issue I've replaced 2 in 3 years.
E54AHS Apr 19, 2019 06:29 AM
if its disconnectedand works ok why replace it old saying if its working leave it alone
E54AHS Apr 20, 2019 12:58 PM
well problem back again thought all was cured
E54AHS Apr 22, 2019 04:14 AM
what one did you get as i see a couple of different types
