Vibration when brakes at high speed
the title says it all... speed around 80 km/h +
some additional info:
Got it and used it for since last summer.. it is R1 concepts PREM.
did some research could the the rotors are wrapped already...?!?!?! from what i've heard from then they are very good rotors
what are the possible problem ?
Oh.. if it makes any different. i did installed it myself.. everything went smooth..
thanks in advance guys
My Ride: 2004 BMW 545I
M sport suspension
Active Steering
M sport interior
Navi
Low ride sports
My Ride: 14 550i
roger gave a lot of good suggestions! how did you break in the pads? if you didn't break in the pads & rotors properly that could cause premature wear.
you need to do 3-4 hard stops from 45-35-45 miles. this way it creates a layer of brake pad material between the pad and the rotor. if you don't do this it'll create a pad to metal scenario which can lead to heat spots eventually causing uneven rotors.
michael
acute performance
michael
acute performance
it could be a couple of things. assuming you do not feel vibration in the steering wheel and only on the brake pedal or in the floor area or in your seat. the rotors could have been already out of round when you purchased them. also did you clean and lubricate the caliper sliders and caliper braket where the pads sit. if they were cleand or lubricated this could cause uneven wear on your pads and will also cause vibration in you brake pedal. depending on the condition of you previous rotors. the pads were already worn to the grooves of the original rotors. when u put new rotors on, that could cause your pads to form a new wearing pattern. which could also be a problem. good luck and keep us posted
I do feel the vibration in the steering wheels. in fact, there are alot of vibration on the steering wheel. again only vibrate at higher speed.
So, the steering wheel also vibrate does it mean the rotor is wrapped?
I shall try the hard stop..!
I will let you know the result.
My Ride: 14 550i
If your rotors are warped, doing the hard stops won't help you. You'll need new rotors.
I will let you know the result.![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
so there are vibration in the steering wheel, means that my rotors are wrapped? how do i confirm it?
thanks
Oh, i also replace the pad when i change the rotors
thanks
My Ride: 2004 530i Black/ Smoked LED side markers/ CF kidney Grille/ Shadowline Trim/Miro 346 V2/General Exclaim 19"/CF Badges/H&R Sport Springs/ Koni FSD shocks/struts/R1 Concepts Drilled & Slotted Rotors/ Hawk Pads/ Mtec V2 lights/
![Innocent](https://5series.net/forums/images/smilies/imported/innocent.gif)
My Ride: 2006 BMW 550i
you could have other issues, such as sloppy wheel bearings or loose suspension components that could cause a whobble, but my money would be on the rotors being warped.
