Vibration after 40
My Ride: 08 535i
Hey guys,
I replaced my passenger's rear upper control arm(wishbone?) today myself. When i got my tires replaced, there were some play in the wheel, moving it back and forth. After replacing my upper control arm(wishbone?), there's still play. What else do i need to replace? The driver side rear is perfect.
Parts # that i replaced: 33-32-2-347-990
If i tighten the top nut a little before half way point, before loading suspension, is that the cause? I tighten the bolt a little bit, lowered it to the ground and then tighten the bolt as best as i could.
My Ride: 2009 535i - Stock...For Now
1989 Chevrolet Truck - Too Many Mods to List
I'm having a similar issue. I replaced both front and rear control arms/bushings and struts within the past year. Wondering if the wheel bearing is the culprit, as pointed out. Mine seems to get better, but not completely go away, at around 55 mph. Almost feels like a wheel is out of balance, but I've had them done twice and gotten an alignment.
My Ride: 2006 BMW 530I
Model Year: 530i
I had a similar issue. Wheels were "slightly" bent (to me, I didn't think tit was that bad), got them straightened and problem gone!
I didn't need to go on any diet; because there were no money left to eat after a few car repairs. ;-)
My Ride: BMW E60
Engine: E60 M54
I had the same issue a year back, vibration from 50 - 55mph.
I replaced a full set of tires, had each rim balanced under load. 1 rim was repaired
To correct what I thought was a bad weld. Took the car to BMW
And they suggested I replace 1 control arm and complete set of bushings.
In the end the silver bullet that addressed the vibration problem 1000%
Cost just over $10 shipping included and made want to slap myself afterwards.
A set of aluminum hubcentric rings on Fleebay.
If you ride is over 3 years and you can feel a miniscule faint of
Vibration either in the seat of your car or the steering wheel stop here
Go to EBay and buy a set of hubcentric rings. It will literally save you thousands. Lol
it's the best $10 bucks you'll spend on your car.
My Ride: BMW E60
Engine: E60 M54
Its not the rims that are causing the vibration , its the rust and oxidation buildup inside of the rims and on the hub itself. cleaning may help a little.
let me know how it works?
