Vanos Check valves
Old Nov 4, 2019 | 06:45 AM
joge's Avatar
My Ride: 2010 535 IX
Model Year: 2010
Engine: 6 w turbo
Default Vanos Check valves
So the E60 with N54 engine (175,000 miles) has been to 3 shops, they are not able to find a diagnosis for the P0174 P0171 lean codes it throw every time it is driven. Some days it will stumble bad and almost die at the first stop sign,.....then it is fine, just a little low rpm hesitation. So far, valves have been blasted, new valve cover (old one was very clean inside) new Blow-by vent hose, new spark plugs, new MAP and Boost pressure sensors, Vanos solenoids have been cleaned and positions swapped, (they were very clean prior to removal)
With how clean the engine is, I doubt that the vanos check valves are bad, but am thinking about pulling them next. Also thinking about replacing the vanos solenoids. Another forum recommended using the Vaico brand as they are more cost effective and a better unti than the BMW oem.
Anyone use these in the past? If so, what are your thoughts.
Thanks
DrLou
Oct 28, 2019 08:53 PM
willowcreek
Jul 30, 2019 08:14 PM
88irocvert
Apr 21, 2015 06:06 AM
bmwdoodle
Dec 17, 2009 06:32 AM
NPe
Aug 6, 2008 03:37 AM
