Valve cover gasket leak after replacing valve cover gasket
Hey guys.
I replaced my valve cover gasket about 10k miles ago along with my spark plugs on my M54 engine.
It looks like it's leaking again from a front cam seal and also from around the backside somewhere.
With only installing it about 10k miles ago, is it okay to remove, clean and re-install? (with RTV again) (vs buying a new gasket)
Thanks!
Thanks!
Assuming the leak is really from the valve cover gasket, I wouldn't reuse existing gasket. Given the amount of time and effort needed to replace the gasket, it's not worth reusing the gasket. Did you use a good torque wrench to tighten the valve cover bolts?
Yeah, I used a torque wrench to torque them to the specs in the Bentley. Maybe I didn't apply enough RTV or cover enough surface area.
Thanks!
My Ride: 05 545i 6MT
Need to apply good enough RTV if the mating area is not flat ( Ex: 1/2 moon).
Also don't settle w/ regular RTV, so far I use this Toyota FIPG which supposedly gives the best seal out there:
Toyota Seal Packing Fipg | eBay
My Ride: 04' 545, 6 Spd Manual, Blk Lthr, Sport Pkg, Sport Sts, Logic 7, Cold Wthr Pkg, Full L.E.D. Interior, Red Eng. Cvr, Mtech Front Bmpr, M5 Spoiler, Matte Blk Grill, Red Caps, Slttd & Drlld Rotors, 20
If I think I've done that is it best to just get another gasket or just check the torque.
My Ride: 2005 545
Yes,, big time leaks,,, will crush and can actually tear the gasket... make sure u get the correct tork specs and tighten them with the correct bolt pattern
