V12.?.? changes?
Old 08-18-2004, 07:49 AM
jtxc's Avatar
Originally Posted by GotBMW' date='Aug 18 2004, 07:33 AM
jtxc: Can you further explain what you mean by the seat and steering wheel memory does not work anymore? I had a problem when they loaded verison 11.2 but it got corrected with version 12.12. Let me know. Thanks
It will not remember my settings, or my wifes. Totally different, so it's very noticeable. Radio and climate settings are remembered. This would happen occasionally before the new update.
Build date was late december.
Old 08-23-2004, 07:38 PM
captainvelcro's Avatar
Ultraplanet: I believe that the seat memory buttons 1 and 2 have a separate memory for each key. So memory 1 on key 1 would be different than memory 1 on key 2. I was confused at first too, but a technician at the dealership showed me using both keys. Works good.
Old 08-24-2004, 08:03 AM
ULtraPLanet's Avatar
Originally Posted by captainvelcro' date='Aug 24 2004, 05:38 AM
Ultraplanet:? I believe that the seat memory buttons 1 and 2 have a separate memory for each key.? So memory 1 on key 1 would be different than memory 1 on key 2.? I was confused at first too, but a technician at the dealership showed me using both keys.? Works good.
That's excellent! I will have to try that out for switching up the set position on those long drives.
Old 08-24-2004, 08:17 AM
GotBMW's Avatar
captainvelcro: so are you saying that each key has two memory positions which are independent of each key???
Old 08-24-2004, 09:14 AM
Iceman's Avatar
My Ride: F02 LCI Individual
Model Year: 2013
Yep. The seat memory has been added to the keys. So now you have two memory positions on each key. mine was built May 10, 2004 and still has two memory positions only. This feature is in the newer software.
Old 08-24-2004, 09:50 AM
GotBMW's Avatar
I have software version 12.12, do I have it?
Old 08-25-2004, 07:08 PM
I don't know what version they added it. I thought I had it all along, but learned about only recently.
Old 08-25-2004, 08:24 PM
Wash n Wax's Avatar
Originally Posted by jtxc' date='Aug 17 2004, 11:09 PM
4) steering wheel button now programmable for phone book
When I hit the steering wheel button for the phone it redials the last number called. Any ideas on how to change this? I have searched with no luck.
Old 08-25-2004, 10:15 PM
530E60NL's Avatar
Left steeringwheel buttons cannot be changed. If you push the telephone button it will call the last number dialed, it works the same as on the e46.
Stunin5
06-14-2015 08:35 AM
DerekShiekhi
08-22-2014 05:00 PM
Ghostteck
11-16-2012 06:51 PM
svtla
11-01-2012 10:40 AM
OEMconcept
Vendors Image Gallery
10-03-2012 04:04 AM
Quick Reply: V12.?.? changes?
