USB / Audio Interface - Advice please
Old 01-09-2008, 09:42 AM
  #31
flipside's Avatar
My Ride: 08 535xi
I have an iphone and it charges fine with the new cable.
Old 01-11-2008, 04:29 AM
  #32
Lord Monkey's Avatar
My Ride: 520d SE Jet black / anthracite Advanced air con Sun protection glass USB Style 244 wheels
Originally Posted by jackstraw' post='515566' date='Jan 9 2008, 06:39 PM
+1 BMW cable is best with the iPod.
BTW, I tried out the USB flash memory drive yesterday. I ended up buying a 16gb mem stick to use in the car b/c my iPod was stolen this week. The flash drive works pretty well, it's a little bit slower to access than the iPod. I also noticed that the music doesn't sound as good as it did on the iPod. I realized that's b/c the iPod has it's own EQ that its going through before going through the L7 EQ. So I guess I need to spend a little time adjusting the L7 EQ to sound better. ... So that's another advantage to using the cable.
Now that I will be shopping for a new iPod... I was thinking about buying the iTouch (which is the iPhone without the phone capabilities). I did a search on the forum and it sounds like the car will not charge it when hooked up to USB. Is that true? Does the iPhone/iTouch require too much juice to charge? There was also some mention of it possibly working with the "new" cable. Is that "new" cable released?
I have an i-Touch so will give it a try in the car to see if it charges up. I was not aware of there being a new cable that works with the i-phone, I thought they were all the same. Will let you know about the charging...
Old 01-11-2008, 05:05 AM
  #33
JSpira's Avatar
You mean an iPod Touch? The iTouch is a Logitech product.
Old 01-11-2008, 09:44 AM
  #34
jackstraw's Avatar
My Ride: *on order* expected 12/20/07: 2008 550i space gray, gray leather, anthracite bamboo, sport pkg, logic7, iPod, HD, Sirius, Navigation, head-up display, comfort access, heated front seats, fold-down seats
Yes, sorry. We're talking about the iPod Touch.
Old 01-12-2008, 11:59 PM
  #35
ricky's Avatar
My Ride: 530e G30
Model Year: 2017
Only to share my experience on USB interface of my new car.
Immediately I have connected a PenDrive of 8GB and it worked very fine.
Yesterday I interfaced a Lacie 60GB little disk 1.8" (FAT32), I don't know if it will work with NTFS format too, I will try ASAP.
Very fast, small and reliable.
Old 01-13-2008, 12:57 AM
  #36
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
That 1.8" "little disk" looks way, way bigger than my 2.5" drive with enclosure -- either way, I'm glad it works for you.
Don't waste your time trying NTFS -- it'll only work with FAT32...
Old 01-13-2008, 02:09 AM
  #37
Dandle's Avatar
My Ride: 07 E61 530d M-Sport.
If I get BMW to retro fit the ipod interface is that the usb conneection you guys are talking about here or is it a separate device?
Old 01-13-2008, 04:10 AM
  #38
Richard in NC's Avatar
What year is your e60? The thread is primarily discussing the 6FL USB/iPod interface option in the '08 models. I assume it can be added later but I've not heard any costs or success stories.
If you have an older e60, an iPod interface can be added that replaces the glove box CD changer. '07 models are easy, '06 models work but should have the iDrive software updated, and '05 and prior E60s need an upgrade if I recall. Do a search for more info.
Old 01-13-2008, 04:18 AM
  #39
I do have one issue when using my iPod Nano with the USB interface. I have the BMW cable btw and find the sound quality just fine.
I leave the iPod in the car all the time. First thing, it always says "loading playlists" or something. I have let it do this for 1/2 hour and it still shows the same message. I only have 1500 songs and maybe a dozen play lists. Should it take that long?
However, within seconds of startup, I can press the volume button. The car will start playing the last song exactly where it left off but in a "now playing" list. I see no playlist info but I can skip forward to the next song within the playlist that it happened to be on. I can also immediately go into my playlists and choose any song from any playlist. Therefore the "loading playlists" function is immediately complete and the message above has to be in error.
Does anybody else have this issue?
Old 01-13-2008, 04:56 AM
  #40
ricky's Avatar
My Ride: 530e G30
Model Year: 2017
Thanks Rudy , you are right no way on NTFS.
This "little disk" is 64x80x18 mm and the smaller 2.5" I have is 75x126x15, how your 2.5" drive ? And which is the manufacturer ?
I could be interested in a smaller one.
Quick Reply: USB / Audio Interface - Advice please
