Urgent - Truck Won't Close!
My Ride: 2004 525i, Metalic Gray, Premium Package
2004 525i, and this afternoon all of a sudden the truck lid wouldn't open, no matter using remote control, key into the trunk key hole, or manual release button next to driver seat, or try to press the handle at the trunk lid. Turning the key in the trunk key hole gives nearly no sense of resistance.
Tonight I inserted the key into the trunk lid key hole, turned counter clock wise by 45~90 degrees (all the way I can go counter clock wise) and stayed a few seconds (someone told me this way the car allows manual release somehow), and then I turn the key clock wise as I would usually do to open the trunk using a key. Trunk lid opened, but now it would not close no matter. Now turning the key still gives me nearly no sense of resistance.
Any clue what is going on? Does this sound a mechanical problem, or electrical? Trying to have some sense before going to a mechanic tomorrow morning.
Also, noticed last few days when trunk lid opens up less than 30~40 degrees, the bulbs in the truck are bright, but then at about 40 degrees or more the bulb (at the center back of lid) will dim to about half of the brightness. Never noticed this before. Is this related to the trunk lid failure somehow?
Thanks!
Thanks!
My Ride: Bmw 530d 2004
My vote goes to wiring harness. My guess is that there is a broken wire(s) somewhere near the hinges.
Especially E61s have had this kind of problems with their trunk lids, but I've read about it happening to sedans also.
- Antti -
- Antti -
Went to a shop today. Turned out the wires in the right side of the truck cover were frailed and broke. The light bulbs with bright and dim light depending on trunck lid position is due to exposured wires touching each other according to the mechanics.
BMW wiring with harness will cost $300+, plus labor, will cost me total of $500+. Asked the mechanic just repair the damage (basically cut and splice...). Total cost out of door $175. Still not cheap given it should not really take 2 hours time in total including diagnose.
umnitza
09-02-2015 11:28 AM
