Upgraded to V32 but STILL no mp3
My Ride: 2005 530D Touring in metallic grey with black leather and brushed silver trim - Msport alloys
Just an additional thought:
My vehicle is now out of warranty and has been for some time.
Does SI B65 30 05 cover me to get this done FOC from a dealer regardless of the warranty status? If so, am I going to get the run-around from them?
Thats interesting; I might drop the Gateway 500 back in and see if that plays. So flashit1, are you saying that you got charged for your work under SI B65 30 05?
My Ride: 2006 E60 M5 (Sepang Bronze/Natural Brown)
Eisenmann Exhaust with Miesterchaft Sections 1 & 2
Evosport Headers
Evosport Pulley
RPi Scoops & Block Off Plates with BMC Filters
Eibach Pro-Kit Springs
20" Breyton Race CS in Polished Silver
It's a "on customer complaint basis only" service bulletin. If you don't complain within the warranty period.. tough shit!
Some years ago I used to have an E60 that suffered with the bore wear problem and BMW changed the block out some years past warranty and with 99,000 miles on the clock. I was very impressed at the time.
I asked my main dealer about the service bulletin, they knew nothing about it as it would appear to be valid in US only.
I had my i-drive software updated a few months ago to v32 by an independant dealer mainly to enable mp3, but was told I have the business CD player and the prof version is required.
I too will be fitting a Dension 500 and fingers crossed the text function will work (seen reports of both text working and not working) on non nav models.
Interesting, if you look in this thread it points out that you actaully do not need to enable MP3 to get the Denison working. All you need to do is enable the OEM Ipod support as the Denison looks exactly like the OEM model to the car.
Thoughts?
https://5series.net/forums/index.php?showtopic=71577
Thoughts?
You guys are a superb help.
So, having read through the thread linked in post #17 and sitting down with a brew to think, I came up with a plan.
Remove the CDC and just go straight to GW500. I don't need the CDC if I can get my ipod working.
Reinstalled the GW500 this morning and the car doesn't see it. No surprise there as I figure i need the OEM iPod interface enabling. What did surprise me was then when i phoned the tech to arrange, he tells me that the OEM iPod interface and the MP3 enable are both the same thing on the Progman system. He figures that the reason it isn't working is because now I have removed the CDC, it needs to come out of the Vehicle Order to prevent the system seeing it as an error.
So, does this sound right? also, are the "MP3 enable" and "OEM Ipod interface enable" the same option on the Progman or are they different?
The saga concludes, it would seem.
With the GW500 installed and a bunch of paperwork supplied to the tech, the iPod now plays as it should.
I still have no idea why it didn't work the previous two times it was tried but I'm now another ?100 lighter making the whole system pretty expensive; ?200 spent on software updates for the car and another ?250 on the GW500 makes it breath-takingly costly. Still, it is done now.
Many thanks to all on this thread who helped with the info; I think I would have given up without it.
