upgraded to 20" but ... intermittent 'traction' light
Hi everyone,
I have recently acquired an 08 535xi.
Put on some 20" staggered (mine already had staggered 18" from the factory)
running 245/35/20 and 275/30/20 (same width as my factory set up)
I am getting intermittent 'traction' light come on especially upon rolling from standing or hard/sharp cornering![Frown](https://5series.net/forums/images/smilies/imported/sad.gif)
when the light flickers, of course the car slows down, I back off the throttle then everything's fine.
So far... I've been driving around with DTC off so I don't have to deal with the traction light.
Anyone with staggered 20" set up on Xi AWD model with similar 'traction' issues??
I know I should have gone to 245/30 and 275/25/20 as I went up 2 sizes from factory but with H&R, I wanted more 'meaty' tires... Also, still rolling sizes are within 1% difference which I thought was minimal.. no??
thanks in advance for any insights, inputs.
Jon
Jon
My Ride: Bmw 530d 2004
I'm not sure but could it be because of the slight difference in overall diameter between the front and rear tyre?
Front: Overall Diameter: 26.75 in / 679.45 mm
Rear: Overall Diameter: 26.49 in / 672.84 mm
0.26" / 6.61mm is not much though...
- Antti -
edit: Or then the rubbers might rotate/move/turn on the wheel if they are recently mounted. On the other hand, this could appear on a hard acceleration only.
- Antti -
My Ride: BMW E-60 530I
what, why would u put staggered on xi? I thought all the wheels have to have same overall diameter or it will damage the all wheel drive system.
- Antti -
- Antti -
Yeah... my thoughts were same...
not sure why with such a minute difference, it throws off the light???
245/40/18 and 275/35/18
factory sport 18" wheels option
overall rolling diameter is almost identical front to back even though they are staggered.
I did some search and other forum members with Xi have successfully ran staggered 19's or 20's with no issues.
not sure why I'm getting traction lights sporadically...
any other insights??
Different brands.
Fronts were Continental Extreme Contact, forgot the rears but they were brands I was unfamiliar with...
I would have never done that myself but...I bought them like that from a friend who had them on his F10 535i xDrive.
I didn't know they were different brands until they were dropped off at my house![Frown](https://5series.net/forums/images/smilies/imported/sad.gif)
Treads were very similar in design though.
Could this be the cause???
Different brands.
My Ride: 05 545/6
tread design is only one aspect of a tire's characteristics. The compound used is also very important. I'd say your problem lies in the fact you've got different brands on each rear tire of questionable quality.
Tsoup
15
12-20-2021 11:14 AM
550iwa
03-27-2015 06:45 AM
