UhOh What does this symbol mean????
My Ride: G30 M550i
Model Year: 2018
Originally Posted by Craggy' post='551657' date='Mar 27 2008, 09:30 AM
Would connecting a carputer to the power lines that were originally powering the CD changer in the glove box and leaving it in standby overningt cause the car not to go into sleep mode?
I recently installed this but the error symbol didnt show up for a while after. Does the car monitor the power being drawn on variou 12v lines to see if something is stil active or how does it know a device is using power continuosly?
If this is the problem where can I get a 12v line in the front of my car that is not monitored or wont show this warning symbol?
Cheers for replies.
Cheers for replies.
Stay tuned for a technical document on the complete E6x power supply...
(For a quick overview, you can take a look at this post -- I will be posting a newer, more comprehensive version of the .pdf in that post in our technical gallery and will link to it here as well as there...)
Edit: Here's a link to the updated power supply document in the gallery:
http://forums.e60.net/index.php?autocom=ga...i&img=10935
Enjoy!
Rudy, your a wealth of knowledge as always.
So as of yet there is no way of me leaving a carputer in standby over night without the car complaining of continuous power draw. How about a second battery? Is that or any other solution possible?
My Ride: G30 M550i
Model Year: 2018
You might want to post a new topic in the mod forum since this one has sort of taken a turn from the original topic. The modders may notice it faster if you post it there...
Originally Posted by Rudy' post='551905' date='Mar 27 2008, 02:40 PM
I hope some of the "mod experts" here can chime in. I'm not one to do this kind of stuff but if there's a way to do it, someone here will know how.
I have noticed that when hooking up my PC based OBDII scanner/recorder (which has a smart cable with timing logic powered by the OBDII connector) the car will not go into sleep mode after the key is switched off.
My Ride: 07 550 i, mystic blue, black leather, cold weather package, nav, sport, shades, bags, rear heat, V1 hardwired.
05 F350 TD Crew Cab
04 Range Rover HSE
91 964 C4 Cabrio
07 997 Turbo Cabrio
Rudy mentions that his car seems to "power up" when he retrieves something from the trunk. I always here some sore of noise when I open the door the first time, or the trunk, some whirring sound sort of like a compressor. I also swear I hear a hard drive type noise in the front of the car after I shut the car off and listen to the last final strains of an opera. But I digress. Back to the OP, my 964 will run the battery down in about two weeks if I don't attend to it or drive it. I ended up buying a battery tender for it, hard wired it in, and just plug the damn car in after I use it. These things work so well I installed them on the TD Ford, the boat, and if it ever freaken quits snowing/raining/blowing here, I plan on putting one on my little JD tractor.
My Ride: G30 M550i
Model Year: 2018
Rudy
03-26-2008 08:37 PM
