Tyre wear and wheel alignment
Old Dec 24, 2007 | 02:48 AM
smarty156's Avatar
I'd like to know what is the normal tyre wear pattern for a 530D SE Touring (2004).
The reason I ask is that this is my first rear wheel drive car and also my first BMW. My last car was an Alfa Romeo 156 and these were notorious for uneven tyre wear (wearing the inside fronts a lot quicker than the rest of the tyre).
I've noticed the outside fronts are wearing more than the rest of the tyre - is this normal or do I need to get the alignment checked? If so, can anyone in the UK recommend a good wheel alignment place in north Kent (or even south Essex as I live near the tunnel)?
The car is currently running on Bridgestone RE 050 run flats (245/40 x 18).
Thanks.
Old Dec 24, 2007 | 03:19 AM
colejl's Avatar
Thanks.
I'm afraid this is a side effect of the camber and runflats. You must keep an eye on the insides as they wear really quickly due to the stiff sidewall. Since I ditched the runflats things are wearing more evenly...
Old Dec 24, 2007 | 04:02 AM
iversonm's Avatar
My Ride: E46 330, E60 550 on order: Carbon Black/Natural Brown, 6MT.
Thanks.
Usually, the inside rear wears the fastest. I wouldn't expect to see the outside fronts wearing abnormally, but a slight bit of wear on the outside would be normal due to cornering.
Old Dec 24, 2007 | 05:30 AM
colejl's Avatar
Whoops, didn't fully read your post... How much cornering are you doing? And how uneven is the wear? (How many mm outside, middle and inside)
Old Dec 24, 2007 | 01:16 PM
DrLev99's Avatar
Personally, I've developed a "saw-tooth" pattern on the outer edges of both my front and rear summer Bridgestone Potenza RE050A's. They are not runflats. I've had my car aligned at least 6 times since May, so who knows? I feel it moving my fingers from back to front on mine. My inner edges are fine. Anyone else notice that uneven pattern as you drag your fingers along your outer edges?
Old Dec 27, 2007 | 02:04 PM
smarty156's Avatar
Have had that before on front motorbike tyres - due to heavy braking! Do you brake hard?
Thanks for all the other replies guys - I haven't had the car very long so it's not down to how I drive.
Old Dec 27, 2007 | 09:51 PM
DrLev99's Avatar
I don't brake hard. And I really didn't abuse the tires or car at all this past Summer. Maybe I should start! Some say the saw-tooth pattern is a "toe-in" issue, but it's never shown issue on the alignments, just camber problems. I guess that could do it too? I have felt many tires of mine in the past with the same wear, so who knows?
Old Jan 2, 2008 | 04:05 AM
smarty156's Avatar
Well, last weekend I got the wheel alignment checked and it was out all over the place.
In fact, one front wheel had a bit too much toe in and the other had slight toe out!
Cambers were also out of spec front and rear.
Had it all fixed and it does feel better. Hopefully the tyre wear will now stabilise and go back to normal.
Old Jan 3, 2008 | 07:07 AM
artc's Avatar
My Ride: April 2007 520D M Sport LCI. Automatic. Sunroof. BMW Bluetooth. Deep Sea Blue Metallic, Natural Brown Leather.
Can the alignment be checked with worn tyres on the car?? Will the irregular wear not effect the geometry of how the wheel / tyre meets the road?
Old Jan 3, 2008 | 08:16 AM
DrLev99's Avatar
The alignment tools measure things from the wheel hubs, and the tires won't affect anything in terms of getting it into spec. You could align the car without tires, theoretically. Now that doesn't mean your car will ride perfectly afterwards if your tires are bad...
madein
Jun 6, 2015 11:48 AM
CertifiedOfficial
May 21, 2015 12:42 AM
TexaZ3
May 6, 2015 09:54 AM
Daniel_gnt
Apr 20, 2015 06:37 PM
bananfiu
Mar 14, 2015 02:08 PM
