Turtle wax for headlight lens resoration
i bought one today and i followed wvery step but at the end when i wiped it with that snall white things now the headlight is sticky it says it will work in 24hrs after 24 hrs should i buff it with a microfiber cloth or what?
That's not going to do anything for you. Where did you get this idea? Plastix or some other UV protectant would work but turtle wax? If you want it to last and not have any issues going forward you should take your lamps out and have them clear-coated with standard clearcoat. protects against everything. I did a DIY sometime ago about this.
My Ride: 2007 525xi
I think he means he used this:
I used that on my girlfriend's Grand Marquis. Worked out pretty well. Wasn't as good as brand new, but it was a hugee improvement from how they were before. They were quite shiny. Though I'm sure there are probably some better products out there.
Oh, and to answer your question: After doing the part with the little wipe that was in the baggy, I just left it there for a few hours, and then put the orbital on it.
A lot of us restored headlights here with different methods. Only 1 method will withstand the test of time.
https://5series.net/forums/topic/102...1#entry1219562
I thought I would add a few comments. I work in the plastic industry. These headlight lenses are made of a plastic called polycarbonate. You may have heard of Lexan as a tradename, for example. This plastic has poor UV (sunlight) resistance. It will yellow, haze and crack with extended UV exposure. Therefore, the lenses are coated with a silicone hardcoat. This hardcoat will not last forever either. I do find it odd that it seems very unpredictable...could be the quality and different suppliers the auto companies use. It certainly matters where in the country you live (e.g. Florida or Arizona will be much worse than Minnesota) and if you park outside a lot (do you park the car in a parking lot outside at work all day?, or in a garage?)
Anyway, my concern over these polishing kits is you are basically removing this hardcoat and exposing the polycarbonate, which is much less UV resistant than the original coating. You could try to polish and basically continue to do so on a very regular basis.
Someone commented earlier and I have to agree, the only long term method is to polish completely and find a paint shop that can clearcoat the headlight.
