Turbos, Injectors, HPFP, Water pump, Programming, LOF, Brake fluid flu
I brought the car in for an oil change and brake fluid flush, and slight "ticking" noise when cold.
The ticking noise turned out to be the turbo wastegates, and both turbos were replaced.
The electric water pump was running longer than it should after the car shut off, so that was replaced.
All injectors were scanned, found to be all from the "bad batch," so all 6 replaced.
The High Pressure Fuel Pump (HPFP) was replaced and the ECU was reprogrammed (both per the recall)
Front brake pads and rotors replaced.
And then the oil change and brake flush, which I originally brough the car in for.
The car is now dirivng as well as when I brought it in! ;-0
This was all covered under warranty (for a cost of about $6,500 USD paid by BMW), but makes me wonder if I want to keep the car when the warranty runs out...
Gotta love it. ;0
My Ride: 04' E46 325i Sold
05' E60 53oi Sold (tranny issues)
08' E92 328i coupe 6spd MT (Current ride)
WOW thank ur lucky stars for warranty! lol.. hey dont worry just get it CPO'd and by the time that runs out u can keep it or sell it
My Ride: Coming soon...
Don't forget that the price the stealership will quote you is always high. A qualified indy will be able to perform the same work at a lower price, so the actual cost of ownership should be a lot less.
chadillac2000
42
09-13-2017 11:15 AM
Glowin
04-13-2015 02:42 PM
