Turbo lag
Old Oct 17, 2004 | 04:29 AM
E60525d's Avatar
When i start to accelarate, between about 2200rpm and 2500rpm it feels like there is turbo lag. It kind of feels like that the engine is pulling back. Is this normal? The engine has done 2000miles.
Old Oct 17, 2004 | 05:30 AM
Flowerfred's Avatar
[snapback]45840[/snapback]
Come to the meet and you can compare a few cars..
Old Oct 17, 2004 | 06:20 AM
E60525d's Avatar
I would love to come but Cant.
Flowerfred's Avatar
[snapback]45871[/snapback]
It is like with the Mint commercial; you need a very good reason not to..
Old Oct 17, 2004 | 08:52 AM
streak's Avatar
Try putting the car into DS as well as using manual mode and see if the same happens.
What happens up to 2200rpm and 2500 rpm?
Do you feel it pulling off from stationary or while on the move?
With my car the lag is felt before you get to 2000rpm so you may be feeling something else.
Old Oct 17, 2004 | 09:53 AM
E60525d's Avatar
Before 2200rpm its very smooth, it climbs up the rev range very nicely. But between 2200rpm and 2500rpm, the acceleration takes a small bump. It feels like the engine is producing no more power than it is but the revs are rising.
Old Oct 17, 2004 | 10:13 AM
streak's Avatar
I doubt if this is turbo lag. We had a similar problem on our X5 3.0D. Turned out they pinched a gasket when they replaced the injectors.
Get the dealer to read the fault memory they will hopefully
pick something up that may point to the cause.
Old Oct 17, 2004 | 12:15 PM
Jimbo's Avatar
The gas models have been reporting and acceleration lag as well.
Old Oct 18, 2004 | 12:36 PM
E60525d's Avatar
Someone told me that the flat spot is due to the reaction of the particle filter. is this true?
Old Oct 18, 2004 | 01:29 PM
smokin's Avatar
Originally Posted by Flowerfred' date='Oct 17 2004, 07:30 AM
Come to the meet and you can compare a few cars..?
[snapback]45854[/snapback]
What meet
