Trunk opening wildly, rocks the whole car
My Ride: 2004 BMW 525i, Premium Package, Premium Sound, Sports, Navigation
Hi,
My 2004 525i has a problem. When the trunk is opened with remote (or with little manual support) it swings open rather fast. So much so, that it rocks the whole car 2-3 times. Not sure whats wrong. Irvine BMW stealership said, they need to do some diagnostics. So about $180 just to find out the problem. Can anyone tell me what could be the problem and its fix? I live in Orange County, so if someone knows a good mechanic who can fix this without robbing me, that would be most welcome.
Charan
Charan
My Ride: 530i
Engine: M54
remove the left and right inner trim panels from the trunk. as soon as you do, you're going to see a spring with three or four different 'attachment' points. try them all, see what works for you. FWIW when i was up at the dealer a couple of weeks ago one thing the sales person mentioned to me was the world famous 'E60 smack your friend in the face' trunk release. so it's kind of a 'they all do that' thing.
good luck.
good luck.
good luck.
good luck.
By "the left and right inner trim panels", do you mean the woolen/plastic cover inside the trunk near both the tail lights, where there is a small compartment on left and a small net on the right?
I see that on left there are two plastic screws, which I could try removing. However, on right its not a screw. Just like a flat head rivet. Can I just pull it? I dont want to break it. Any trick to open the right side (if I have understood "the left and right inner trim panels" correctly)?
- Charan
good luck.
good luck.
Thanks for all the help
- Charan
