Trunk opening sets off alarm
Old 08-21-2006, 06:32 PM
wnrussell's Avatar
Just lately, opening the trunk (remotely) sets off the alarm if the vehicle is locked. I never use the metal key to open the trunk.
Used to be, you go to the grocery store, close the door and wait to hear the acoustic confirm on lock. Come out of the store, head straight to the trunk and pop it open on your way to the car without setting off the alarm.
Isn't that the way it is supposed to work? You don't need to unlock the car doors to avoid triggering the alarm, right?
Old 08-21-2006, 07:07 PM
kscarrol's Avatar
My Ride: E90 M3
Model Year: 2011
I would say if it just started doing this, head to the dealer. The trunk button on the remote is also the panic button. Some folks have had problems getting the timing right to just pop thhe trunk or holding the button to long and setting of the panic alarm.
Old 08-21-2006, 07:53 PM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
There's a ton of posts here about this very thing. kscarrol is right, if this is something that is happening all of a sudden (you're already aware of the panic feature) then you might have to have things checked.
If this is something that's happened since day one and you're just now getting frustrated, try reading some of the following to see how many of us have solved this problem:
http://forums.e60.net/index.php?showtopic=1173
http://forums.e60.net/index.php?showtopic=7696
http://forums.e60.net/index.php?showtopic=2627
http://forums.e60.net/index.php?showtopic=13901
(there are plenty more topics out there but the above should be enough...)
Old 08-21-2006, 08:42 PM
525iSE's Avatar
How do you set off the panic button without opening the trunk? For my car, if I hold it then the trunk pops open after like 1 second, I don't see how holding it longer will be used as the panic button at all. Unless the trukn pops open then the car alarms goes off... thats just inconvenient. Sorry for the off topic, and i agree with everyone, you should get your car checked out if it just started doing that...
Old 08-21-2006, 08:52 PM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
I think the panic feature is only on US cars (or maybe North America...)
Old 08-21-2006, 09:24 PM
Busta's Avatar
I've had this problem off and on from day 1. Not really concerned about it.
Old 08-21-2006, 09:57 PM
DBU
DBU's Avatar
Yep. All USA cars come standard with the alarm feature, which is an add-on option for most other markets.
Old 08-21-2006, 10:24 PM
aybeesea's Avatar
Not seen it even mentioned in UK.
But that could just be me being being not very observant.
ABC
Old 08-22-2006, 09:09 AM
wnrussell's Avatar
Thanks, Rudy. I did try searching but I guess with the wrong, or too many Keywords.
My service guy said that you can add a panic delay to the CIP programming to get an additional 3 seconds before the alarm goes off. I'll try that and post the results.
Old 08-22-2006, 10:28 AM
Green-Crayon's Avatar
This topic still makes me laugh - over a year into my car and I still say "one thousand one, one thousand two" as I am opening the trunk! Works everytime - I just feel like a dope saying it to myself.
Quick Reply: Trunk opening sets off alarm
