trunk only opens via the remote
My Ride: BMW 530ix
Titanium Grey
6 months ago or so, my trunk on an 06 530 xi stopped opening when using the manual latch in the back. It does respond to the remote control command. (It also does not open when using the manual switch in the car)
Any guidance before I spent big money at the stealer.
My Ride: 530I Silver gray with gray leather with Premium Package, Logic 7 Premium sound system with Ipod interface, xenon adaptive headlights, Active steering, Power retractable rear sunshade, Comfort seats, Cold weather package and M5 OEM 166 wheels, Sprintbooster. Ceramic Tint all around, Bilstein Sports shocks with Eibach springs, Brake performance Rotors and Axxis ceramic pads.
Did you check if your trunk key hole is on valet mode(key hole on horinzontal position)? If it is, turn it to vertical position.
Engine: N54
In valet mode it would only open with the mechanical key inserted into the lock - not the remote control; the valet would have the remote control in order to drive the car.
This may be true on the 2006 and newer models but not on the earlier models. On the earlier models there is a separate valet key that is to be given to the Valet. My 2004 remote will open remotely the trunk with the trunk manually locked. And because the op's car is a Canada model, this my apply to him as well.
Engine: N54
![](https://5series.net/forums/public/style_emoticons/default/think.gif)
I 'think' it would depend on the key the OP has. if it is this one...
![trunk only opens via the remote-0405key.jpg](https://5series.net/forums/attachments/e60-discussion-2/116223d1482365811t-trunk-only-opens-via-remote-0405key.jpg)
then the remote will open the trunk when the trunk is locked. Give the valet the Valet key '2' only if you have this version.
If he has this one...
![trunk only opens via the remote-06key.jpg](https://5series.net/forums/attachments/e60-discussion-2/116224d1482365811t-trunk-only-opens-via-remote-06key.jpg)
then the remote will not open the trunk. remove the removable hard key from the remote before giving the remote to the Valet.
It doesn't matter what year model, for as long as the trunk key hole is horizontal position, the trunk can only be opened by remote. The trunk latch and inside the car switch won't work,
This is what I thought too but the way it is written in the manual says...
for 2004
Attachment 116232
For 2006
Attachment 116231
for 2004
Attachment 116232
For 2006
Attachment 116231
xiTouring
08-17-2015 07:13 AM
