Tried to install my new blanking caps for the inlet manifold.
#21
Originally Posted by pauld30' post='858731' date='Apr 26 2009, 12:18 AM
Hi here what model e60 have you got. i tried invain to get my egr valve out. couldn't get to all the torq bolts, 3 off or the 4 allen bolts. it didnot look that bad so just put all back togerther. 530d mine is.
#22
So is there a definitive cut-off date for when the uprated flaps were fitted. I have a 525d that was reg'd in Jan 05. Any ideas if mine has the updated ones? I'd have a look under the bonnet but every time I get near to anything mechanical I get a nose bleed!!
#23
#25
#26
My Ride: E60 530d M-Sport
Originally Posted by latho' post='854944' date='Apr 22 2009, 10:43 AM
Cheers Rob,
I think i'll be leaving them in place for the time being, I've serched and not found any 'first hand' reports of issues with the 4.5mm shaft, if anyone has heard, and has a link, please post.
Dom
Dom
#27
Originally Posted by Phantom Mark' post='861479' date='Apr 28 2009, 05:47 PM
Thats also my current experience and approach, and when you consider when things go wrong people tend to end up on a forum like this I think it speaks volumes, ie I have never seen a post here on these forums from an owner with updated flaps claiming failure.........and if your gonna hear about it first hand here is likely the place you would hear about it.
I've talked with member Hellraiser and he had four broken "updated" 4,5mm swirl flaps. They weren't fully broken when he got them removed, fortunately. Their axels were critically bended and just about to break.
#28
Hmm, that puts a different light on the matter then...............
Fek, I have no clue where to start removing my damned inlet manifold (whilst I appreciate there is a guide), let alone the balls to do it, cant afford for my car to be off the road a single day if I screwed it up
#29
Or get someone to help you out . Then it's twice as fun.
edit: Umh.... Somehow I managed to make that sound dirty .
#30
Anzafin is right, it is easy to follow his guide. Just take your time and place the parts you take off in a safe place layed out in order of how they come off. I have since had my mainfold off a few times now to check on some stuff.
