The Triangle symbol
My Ride: 2005 525i: Mystic Blue, Auburn Dakota leather Premium and Winter Package, Xenons
When i was on a long drive to South Jersey i noticed a triangle symbol blinging next to the service bars on the lower right hand corner on the I-drive screen..what is the symbol for ?
its an orange triangle symbol ...i dont know if its for my bluetooth phone or what not?
My Ride: E61 525iA Build 2004/08. "Safirschwartz Metallic". Navi Pro, Adaptive Headlights, Bi-Xenon, Panorama Sunroof etc... CIP 18.00.01 (No noticed bug)
It means that you should go to "check control" in your iDrive menu and check for errors! Probably nothing serious unless you have some nasty message on your iDrive-display... I had that symbol the other day when i only had 8 litres (is that 2 gal.?) of gas left.
My Ride: 2006 530i Sport
Silver Gray - Black Leather - Anthracite Maple
Manual Transmission
Premium Audio
Cold Weather Package
Rear sunshade
Sirius Radio
Autobahnd Roadblock (3M) film kit
[snapback]159199[/snapback]
I think we're all assuming it's the triangle with the exclamation point in it (!). If it doesn't have this, it could be the triangle that indicates the phone is roaming.
Several benign things can cause the "check control" - not wearing your seatbelt, not having accepted the iDrive warning yet, gas reserve level met, and having DSC/DTC turned off. Check the service messages to see if there's a problem or press the bottom button on the trip computer stalk for a systems test. If there aren't errors, you'll see a large "OK". If there is something wrong, you'll see the car elevated on a lift.
Triangle with ! in the middle... I get that everyday! Always for some stupid reason... BUT I'm glad!!! I'm glad its for a stupid reasaon... I dont want it to be major! I mainly get it for driving past me set "MAX SPEED"
That might be true! (I had the /!\ too fresh in mind). If it's the roaming triangle, that means that you are connected to another network/operator than your "home" network/operator. Are you travelling outside your own state? Here in Europe we normaly get that triangle when we enter another country (as national roaming is very unusual here).
no it wasnt the "!" ...im not that clueless guys....come on now..hahah....it was the roaming one...i guess since i was traveling through the boonies it came up...even though I do have a national plan...
My Ride: 2006 525i Silver Gray/Auto/Prem/Xenon/Nav/Sirius
You'll get the roaming triangle alot if you're a Cingular or ex-AT&T customer. Your phone will use whichever network has the best signal, but still see it as roaming. Cingular will eventually "rebadge" those AT&T nodes it is keeping.
Originally Posted by alohalc' date='Aug 15 2005, 03:07 AM
yes, if it's white, solid triangle, that's roaming.? i have that every time i'm inside my car with my phone.
[snapback]159413[/snapback]
