Transmission slipping or bad maf sensor ?
My Ride: e60 530d
![Unhappy](https://5series.net/forums/images/icons/icon9.gif)
2003 bmw e60 530d automatic transmission (300.000 km). Im starting to notice
that when heater is on and even when sometimes off, when changing gears
rpm drops two times instead of one.
We plugged in computer two times and no trasmission errors, we got maf sensor error tho and many other errors due to low battery.
It dont happens all the time and it happens more with heater on and while cruising low speed.
My Ride: 2009 528i xdrive
I am not trying to imply that will fix your problem, rather I am saying that many transmission problems are often due to lack of service. If you are planning on keeping your car for a long time, I would have it serviced ASAP. I really can't see what the heater would have to do to the performance of the transmission. I assume that shifting is performed as a function of engine load, so it could well be a MAF sensor problem. If you have a low battery, I would replace it, as these cars do not respond well to low battery conditions.
b16gtf
05-14-2013 07:32 AM
