Transmission Slam
#22
My Ride: 2006 525XI, Jet black on Dakota beige. Premium and winter packages. I consider myself a purist and intend to keep my car absolutely stock and shiny.
2008 328I Convertible, Sapphire black on beige interior. Premium package, NAV, iPod adapter.
Retired: 2002 325I, Titanium silver on black leather. Premium package. Absolutely stock and proud of it.
Originally Posted by subarashi' post='1097083' date='Jan 24 2010, 09:29 PM
I'm going to take the SIB to the dealer. In my case, the problem is intermittent which makes a 'drive' with the foreman/chief tech rather limited.... But since the SIB is out, we will see if this makes a difference...
Can someone explain what the SIB does? What's with the change in the idle control????
#23
My Ride: 2008 535i w/ Sports & Permium Pkg. Silv/Blk
2008 VW R32 w/Nav.
1992 VW Corrado Silv/Blk-retired
2001 530i Sports/Premium-retired
<div class='quotetop'>QUOTE (ENstig8or @ Jan 23 2010, 04:44 AM) <{POST_SNAPBACK}></div><div class='quotemain'>Mine only does it when the car is cold. Once I've driven it for a while and it's warmed up, it will not do it.</div>
Here is a link to the updated SIB:
http://www.bmwtis.com/tsb/bulletins/bullet...mp/B240308g.htm
#24
2008 VW R32 w/Nav.
#25
My Ride: 2010 VW Passat Wagon 2.0l Tsi
Grey/Grey Budapest 18"
Lost to HPFP issues:
08 535i sport pkg
Lost to Dreaded E61 Sun roof leaks:
07 E61 530Xi
The dealer was never able to fix it on the 535i, but on the 530 it had it bad and they updated the software and cleared out all the transmission adaptions. It drives totally different now...no slam , the thing down shifts going down hill, hold gears better going up the RPMs, actually has some punch off the line now too.
BIG difference. No slam in 1-2-3 or from dead stop like it did when I got it.
#26
My Ride: e60 520d 2006 model
The same thing happened today on my 520d. it's been 3 weeks since i noticed that some torx bolts on the gear oil pan had leak from the atf oil. just a spil. So i had that gear slam at the time the car stopped moving. Not all of the times i stopped but enough to make me wonder what's next. i have 85000 miles about and still haven't changed atf oil. i also tried twice this ( 20 seconds reset trick). Could it be anything wrong when two months ago i changed all by my shelf the vibration damper (pulley) and i had to force a lot to replace it?
#27
My Ride: '08 530i Luxury LCI
I send my car to the service centre and done this NIC reprogramming thingy, the car works well and no more transmission slam during cold start.
#28
In October '09 BMW issued the third iteration of SIB 240308 to address the tranny slam. My dealer tried to fix the problem in my '08 E61 using the previous two versions of the bulletin to no avail. This third one fixed the problem by deactivating the neutral idle control. I have had no problems for the past two months. Here is a link to the updated SIB:
A temporary, but unsatisfactory, way to avoid the problem is to shift to DS when stopped if the car is cold.
![Angry](https://5series.net/forums/images/smilies/imported/angry.gif)
And from what I've been reading this DAMN SLAM applies to nearly all E60! including my N62 545
I'm very interested to here the follow up of OP's situation...
