Transmission Oil Leak
Location: Calgary, AB - Canada / Buenos Aires - Argentina
My Ride: 2006 BMW M5
Originally Posted by lcc014' post='825375' date='Mar 24 2009, 08:01 AM
Just dropped off the car to dealer. They will look into it and change the O-ring. I have extended warranty on my car. If extended warranty does not cover the cost, dealer will do that as a good will. Will see ....
Also, dealer will do the airbag seat mat recall today.
did you tell the dealer that you replaced the tranny fluid yourself?
My Ride: E60 530i
Engine: M54
I saw posts from e90 which also have this leak too. BMW is aware of this problem and it has a service bulletin SIB 24 08 06 to address this issue. However, I could not find this bulletin in Internet. Hopefully, someone in this forum can post this bulletin for us to reference.
One must use the exact transmission oil as spec'ed by BMW. If you don't, you will definitely blow your transmission. I know my 06 uses Shell oil, which is not available anywhere but the dealer.
Regards.
Regards.
My Ride: E60 530i
Engine: M54
Update : I got my car back. Dealer replaced the oil pan gasket (24-11-7-571-235), sealing sleeve of the black connector (24-34-7-588-725) and 3 (qts/liters) of tranny fluid.
Total repair cost is about $1119 with only $166 for parts. Labor cost is about $953. I am lucky to have the extended warranty which covered all the cost. Dealer told me to check any more leak after a few days of driving the car. Will keep an eye on it.
Same problem on 04/545. within 10$ of your cost too.
... serious labor - full days worth. The oil is liquid gold too.
Anyways, do you know if the broken part was replaced with the an improved design? I would hope so since this is addressed in SIB.
I asked, was told it's a different part number- therefore must be a "better" design. Just checking with others.
-mike
-mike
My Ride: E60 530i
Engine: M54
-mike
-mike
I also looked at RMEuropean.com. They sell this sealing sleeve for about $15.00 with same part number: 24-34-7-588-725. So dealer may just installed the same part (design) to my tranny. Do you know the part number listed on your invoice ??
Also, did you measure how much oil drained before you added some? I wonder if you added too much oil which could have blown the seal.
Thanks.
My Ride: Mini Cooper
In HK it only cost $350us to change it. parts+Labor
that good news that it is OK now.
My Ride: E60 530i
Engine: M54
Originally Posted by 968turboS' post='826275' date='Mar 25 2009, 11:38 AM
Wow, that's a lot of $$. Not sure why they would charge so much for labor. It looks like they only used 3 quarts, which means they saved most of the oil and reused it. They added 3 liters for what you probably lost from the leak. I am curious why the labor is so expensive. You would think at max 2 hrs of labor.
Thanks.
Thanks.
I followed the TIS instruction to pump in fresh fluid. However, we have no way to check the fluid level because it is done via the computer.
My Ride: E60 530i
Engine: M54
Originally Posted by pinguhk' post='826277' date='Mar 25 2009, 11:39 AM
wow that alot of money for all that almost 3 times as much. :thumbsdown:
