Transmission oil
My Ride: BMW F10 528xi
Model Year: 2013
Transmission oil
hello,
I want to change the tranmission oil of my bmw e60 '05. My question is how much oil I need. I will completely change the oil and put new in. I also want to change the oil filter.
Can someone help me? Thanks
Model Year: 2013
Hi. Today I called two different dealers for the oil filter. The dealers both sell only complete the transmission container including the filter. But I only need the oil filter.
Is there a way to get only the filter?
Thanks
Thanks
You have to use special transmission fluid for ZF 6HP (from BMW or ZF Lifeguard 6, Ravenol 6HP, Meyle ATF plus 6).
The problem is how to replace the maximum amount of fresh oil and use the minimum amount of expensive fluid (about 10-12 liters), because only about half amount of old fluid can be drained through oil pan.
call these guys, OEM stuff and prices can't be beat
BMW Parts and BMW Accessories | Bavarian Autosport
My Ride: E60 M54
Model Year: 525i 2004
Use ZF lifelong 6 oil and if you are changing the filter, the pan will be replaced with it and you will need 6.6/6.7L of the oil. Be careful not to touch the transmission when it is hot and take care of those torx bolts on the pan. Depending your mechanical skills, this job is fairly difficult at about 7/8, and must be done very carefully. Do your homework first before touching anything, as this not a straight forward oil drain fill procedure.
My Ride: 528xi, premium, navi
Model Year: 2010
Engine: N52
A cheap alternative for the OEM fluid would be to use the Land Rover LRN13754 fluid. It is essentially the Shell M1375.4 fluid that was the oem fill in your ZF transmission.
