Transmission Malfunction when wife/brother drives car
Hey everyone, I drive a 2007 530i. I've been seeing the dreaded Transmission Malfunction warning come on the iDrive when my wife or brother drives the car, but haven't had it when I drive it. I've tried the trans reset by holding down the accelerator for 25 with key in ignition, with no luck.
Typically the warning pops up around 80mph or sometimes after the car is slowing down to a stop, and picking up speed again on the side streets.
EDIT: Codes being thrown are P0700 & P17ea
When this happens, we pull the car over, turn it off and restart it and the warning is gone. I'm worried there is something wrong and through my searches it seems it can be anything from an alternator or solenoid, to a complete transmission replacement.
Anyone have any insight on this?
Thanks
Thanks
Check if there are any trans fluid leaks under the car (electrical connector sleeve, pan are the usual suspects for leaks). If you see any signs of leak(s), you will need to verify the trans has proper amount of trans fluid.
How many miles on the car?
Hey PCY
110k for me 2007
I have not noticed any leaks at all, just had radiator replaced due to a crack. However I have seen this trans malfunction before the radiator had problems, so I don't believe it's a result of that. But I am not entirely sure.
110k for me 2007
My Ride: 530i
Engine: M54
I would recommend you find someone who is familiar with the 6HP19 transmission that is in your car and have them drain the transmission fluid, replace the pan/filter assembly, and refill with fluid.
ZF has strict temperature requirements for filling its transmission. It is not as simple as 'drain it out, fill it back up', which is why I recommend you find someone who is familiar with servicing modern ZF automatic transmissions. This doesn't necessarily require you have the car serviced by your BMW dealer. This transmission is used by BMW, Rover, Hyundai; even Ford uses their version of ZFs 6HP26. Chrysler is also using ZF automatics in its cars.
Find a qualified mechanic that is well versed in ZF automatics, and have your fluid changed. When I ran my old shop (early 2000s), we cured many a transmission ill simply by doing a routine transmission service.
you can order parts yourself for less than $300 from thectsc.com
good luck.
You really need to figure out what the codes actually are..
New fluid can't hurt. thectsc.com has a kit with new oil pan (filter is built into it) & REAL ZF fluid.
I strongly recommend not using anything except the real stuff
Depending on the error you are getting, solenoids could be an issue at this point as well. I had all kinds of errors on my transmission that basically meant some clutches were slipping. After putting in new solenoids I haven't had a single error code and it drives like new. This is on a transmission with 207K miles
I have a video of installing the solenoids if you want. Most shops will try to replace either the whole transmission or the whole valve body / mechatronics instead of actually figuring out what's wrong. Solenoids will fix a lot of problems on these though
