Transmission Malfunction
how about year/model/transmission/region?
I will step in for gene here and suggest that you add your location to your profile as it will help other members determine specific information about your vehicle (or something like that)
okay, so i have used my crystal ball to determine you have a 2006 525 with an automatic transmission and you live in california. I am not seeing the part number. here all all the names and part #'s of parts associated with the transmission:
Vent cover
24 10 1 422 142
Vent pipe
24 10 1 422 141
Screw plug with gasket ring
24 11 7 552 349
24 10 1 422 516
Sealing sleeve
24 10 7 536 339
Sealing sleeve
24 10 7 536 340
Sealing sleeve
24 10 7 536 341
24 10 1 422 663
Shaft seal
24 31 7 519 352
O-ring
24 31 7 536 355
Torx bolt
24 31 7 536 356
O-ring
24 20 1 217 321
Shaft seal
24 14 7 571 213
Remanufactured Mechatronics
24 00 7 552 312
Remanufactured automatic transmission EH
24 00 7 547 901
Torque converter
24 40 7 547 576
Gasket set
24 27 7 536 390
Set, blind plugs
24 10 7 536 090
Oil pan
24 11 7 536 387
Gasket, oil pan
24 11 7 540 844
O-ring
24 11 7 520 714
Screw plug
24 11 7 520 713
Torx screw
24 11 7 552 108
Shaft seal
24 13 7 519 344
Compensating plate
24 20 7 521 972
Output flange
24 20 7 552 327
Collar nut
24 20 1 422 170
Shaft seal
24 20 7 571 212
Wiring harness, engine grbx. module
12 51 7 557 842
![](http://static.bmwfans.info/images/epc/MTQ1MjUzX3A=.png)
![](http://static.bmwfans.info/images/epc/MTYzNzk5X3A=.png)
![](http://static.bmwfans.info/images/epc/MTk0OTQ4X3A=.png)
![](http://static.bmwfans.info/images/epc/OTc0MjRfcA==.png)
![](http://static.bmwfans.info/images/epc/MTYwNTc1X3A=.png)
Vent cover
24 10 1 422 142
Vent pipe
24 10 1 422 141
24 11 7 552 349
24 10 1 422 516
Sealing sleeve
24 10 7 536 339
Sealing sleeve
24 10 7 536 340
Sealing sleeve
24 10 7 536 341
24 10 1 422 663
Shaft seal
24 31 7 519 352
O-ring
24 31 7 536 355
Torx bolt
24 31 7 536 356
O-ring
24 20 1 217 321
Shaft seal
24 14 7 571 213
24 00 7 552 312
24 00 7 547 901
Torque converter
24 40 7 547 576
Gasket set
24 27 7 536 390
Set, blind plugs
24 10 7 536 090
Oil pan
24 11 7 536 387
Gasket, oil pan
24 11 7 540 844
O-ring
24 11 7 520 714
Screw plug
24 11 7 520 713
Torx screw
24 11 7 552 108
Shaft seal
24 13 7 519 344
Compensating plate
24 20 7 521 972
Output flange
24 20 7 552 327
Collar nut
24 20 1 422 170
Shaft seal
24 20 7 571 212
12 51 7 557 842
![](http://static.bmwfans.info/images/epc/MTYzNzg3X3A=.png)
My Ride: 525i
wow thanks... its the plug right under the starter... when i was pulling the starter out my friend kind of broke the clips on it... and yes i live in la, california... thanks for Nigel (einstein57) and all his help i found the problem
