Transmission Malfunction
My Ride: 535
car is 2008 535i with 132k miles... tranny fluid was probably never changed.
So i parked on a steep hill, facing up, overnight and i tried driving up the hill and the car felt like it was in 3rd gear barely pulling, or like a clutch slipping. I reverse and drive down the hill and get the dreaded Transmission Malfunction error.
Restart the car, the error went away. Drives normally.Went to get coffee, get back and and try to drive away and the car is barely driving. Limped it a block to a Gas Station with repair shop. I thought it could be low on fluid or needs a new seal. Once i stop, the car won't go into drive or reverse or neutral. It would just go back into park.
The shop ran the code and told me its says the tranny is slipping clutches, dont have the actual code. Pretty much he said i need a new tranny.
Once the car cools down, you can drive it a couple blocks and then it would start slipping and then the same would happen where it wouldn't go into drive or reverse.
I am not sure if i should just change the whole tranny or get a new valve body.
What do you guys think?
Any shops in San Francisco, Bay Area specializing in that?
My Ride: 535
i found a transmission from a low mile 335i for a good deal.
i think the build date is before 03.2007. which i think has a little different valve body and the tcu than the ones after 03.2007. But thats for the E9x 335. so i am not sure how that applies to E6x 535i
u think it will fit?
My Ride: 530i
Engine: M54
If the transmission is slipping you'll get "RATIO MONITORING" fault codes, with something like "4F85" or "4F81"; the last part of that code is telling you which drum has clutches that are slipping (A drum,B drum,C drum, etc etc)
My Ride: 530i
Engine: M54
A transmission that is low on fluid, or isn't building appropriate pressures, will slip and register faults that are consistent with a transmission that has catastrophically failed. The fact that yours does it intermittently makes me think you have a fluid level, fluid quality, or valve body problem. I'd certainly look into those possibilities before I condemned the whole transmission.
good luck.
My Ride: E60 2006 sedan auto
I had the valve body reconditioned and new Solenoids and now all the codes are clear and no problems
I also helped another guy with the same problem in his 525I
same repair to the valve body and solenoids
BMW both times said the transmissions needs replacing
In my short history with BMW transmissions the code for a slipping clutch can be set of from
low fluid
bad seals between the valve body and clutches
and faulty solenoids
Don't be scared to have a go yourself
a lot of great people on this forum to help you as they did me
Cool. I'm not the most knowledgable on trans dtc's but I figured you'd chime in since you've worked on yours quite a bit.
My Ride: 535
thank you guys for chiming in, really appreciate it
i guess i am gonna recondition the valve body first
let me see if i can pull the codes first.
my BMWhat App became terrible after an update they had and i cant get it to work properly.
That is then shown in an error code
that can result in a number of reasons
Kyle is absolutly correct in what he says although both transmissions i have repaired had the same codes 4F85 and 4F81
Thats because low fluid and bad solenoids can also cause the same problems so that the sensors think the clutches are slipping.
All the error codes have never returned since i did the valve body and solenoids
If you are in the states I would suggest you contact seanjordan20 on this forum as he knows a great and reasonable priced company to do your valve body
For himto replace the solenoids alone would have cost $600 but they serviced the VB and replaced all the solenoids and tested the VB for just $700
But of course you will have to remove the VB, replace your filter and fluid so you will be looking at around $1,000
I hope this helps
i'm not trying to disagree with anyone on this forum
everyones been great to me but in my understanding the soleniods and valve body will more than likey be your problem than slipping or damaged clutches
My Ride: 535
thanks, i was actually wanted to talk to you about my transmission problem, to see what your thoughts on it was.
i think i am gonna get my valve body rebuilt and then if that doesn't fix the problem i am gonna get a used tranny and swap in my overhauled valve body.
i am gonna contact seanjordan20 and see what he can do for me.
thanks for the help E60Japanese
