Transmission just went out...now what?
My Ride: 04 525i
I read that you cant put a used transmission in this car what has everyone else done thats lost a transmission?
My Ride: 530i
Engine: M54
You can absolutely put a used transmission in. If you don't want to code EGS in the used transmission for your car, remove the valve bodies from both transmissions, swap your old EGS into the used transmission, and then follow proper fill procedures. All of this information is readily available on this forum and the internet.
good luck.
good luck.
colincoon
03-15-2016 07:39 PM
