Transmission/Gearbox Knocking!
Hi Guys i need your help i have 2004 545i! The problem is when i go from drive to reverse or visa versa and pull off i get a knock/thud under my cente console armrest!
I have been told to get the transmission/gearbox reset do you think this will work? has anyone experienced this? thanks guys
For standard key ignition: Turn to position 2 (engine off) and hold down the gas pedal for 30 seconds.
For comfort access: Push button 2 (I believe) times and hold down gas pedal for 30 seconds.
Originally Posted by Krozi' post='798557' date='Feb 22 2009, 12:33 AM
Make sure you depress the brake ALL the way when shifting to drive/reverse. And do this -
