Transmission fluid comparison
#31
My Ride: 530i
Engine: N52
So if I understand this discussion correctly the Motorcraft Ford Mercon SP ATF is OK for the ZF6HP tranny in the 04-10 530i?
#32
If money is no object most people say you can't beat the ZF LG6 for guaranteed compatibility.
If you use the Mercon SP I would reset the adaptation.
#33
My Ride: 2006 BMW 550i
http://en.wikipedia.org/wiki/ZF_6HP26_transmission
i was reading where the same transmission was used in hyundai genesis, and dealers were charging 75/quart for fluid!
![Embarrassment](https://5series.net/forums/images/smilies/imported/ohmy.gif)
#34
My Ride: 530i
Engine: N52
Thanks to both for the responses.
I plan on doing a few drains until the fluid is clean.
I want to make sure the torque converter is clean as well.
So that will use up a bit of fluid.
I'll advise results.
Confused though about "resetting adaptation"? That's new to me
#35
Ignore what is being said on the page about not resetting the adaptation. They are talking about dealers doing it while the car is being serviced for complaints of transmissions not working correctly, as resetting the adaptation clears the memory and may delete faults which can be used as clues to effect repair.
#36
My Ride: 530i
Engine: N52
Source for the cable please if you know?
I looked up about software download locations but there were caveats. So best place to find the software please?
I would bet this would clear a slight hesitation I have felt going into reverse since the car was new.
Dealer blew me off about it but I felt it was not right.
Many thanks for the response
#37
Bavarian Technic Software - Products for sale
#38
My Ride: 530i
Engine: N52
Thank you, Bimmer52, for the info on software which i will check.
Anyone know anything about either of these adaptive procedures?
Both are obviously non-US cars but any application here?
#40
My Ride: 530i
Engine: N52
So I have been reading more about the "Adaptive Processes", and it seems that the changes through the software are not permanent or am I mistaken?
It seems that upon effecting a transmission adaptive process the computer will again memorize a driving pattern and then hold that pattern.
So am I correct in assuming therefore that in changing tranny fluid to say Motorcraft SP that an "adaptive" process would only assist the tranny's memory in learning the fluid type.
Does the process have a long-term effect on the tranny's proper function or does it have to be done frequently?
