transmission failure message
Old 10-21-2014, 04:41 PM
  #21
KyleB's Avatar
My Ride: 530i
Engine: M54
Originally Posted by e60eric
I would say that the 2-3 shift and the 3-4 shift are always slow, maybe around 0.5 seconds. It is more noticeable when accelerating moderate/hard, because these are the situations where I am trying to out-maneuver someone or getting out of someone's way, and I'm left feeling like "c'mon, c'mon, hit the next gear already!"
The hard slam into 4th happens maybe once a month.
I've debated whether the solenoid/seal replacement would make the fluid flow more consistent and/or faster? But after just changing the fluid and noticing NO difference, I'm a little shy to spend the money.
I would be too. I wouldn't entertain the idea of replacing components until I started seeing some fault codes or experience a hard failure in some component. My guess is that you might be seeing the early warning signs of solenoid failure, or you have an internal seal that's not sealing and pressure is being lost.
I'd just plan on living with it for now and keep an eye on things (regularly check for codes, external fluid leaks).
Old 02-15-2020, 09:01 PM
  #22
Probation Members
gocit's Avatar
My Ride: E60 - 523i - 2008
Hi Kyle, I hope you are still around,
mine is E60 523i 2008, Asia, Indonesia - it says 'transmission faulty', once I scanned it, it says trouble with clutch E. I have changed the whole set of solenoid before, but 5 mo later this problem came up on DS and manual M4-5. some mechanic here suggest to do tranny overhaul, change all the seals, bushings, oil and review the clutch. another mechanic told me the problem is the mechatronic itself. which one do you think I better do to solve this.
best
Old 02-16-2020, 05:57 AM
  #23
scottalexander's Avatar
My Ride: 528i
Model Year: 2010 528i e60
Engine: N52k
If you drained and filled your 6hp19 with LifeGuard 6 every year,
do you still believe the bridge seal is a flawed design and its going to crack at 100,000 miles?
gmcclintock@hotmail.com
10
05-29-2017 10:56 PM
blackbeastt
E60 M5 Discussion
07-21-2015 02:22 AM
E60GUMSL
07-20-2015 03:45 PM
w84me
07-10-2015 10:56 AM
DAVE H
07-06-2015 12:27 PM
Quick Reply: transmission failure message
