Transmission Failsafe Error 5088 - What is broken?
Old Sep 18, 2016 | 10:10 PM
bornonmarch's Avatar
My Ride: 525i E60
Did you fix your car? I have the same error message '20616 clutch choice Sensors wrong". Mine is E53 2004 3.0D with GA6HP26Z transmission. It pops up the TFP error when the temperature gauge shows a quarter mark. The reverse is OK and only pops up the error when it moves to D. Even when engine is off but key is in on and when moving the selector gear to D, the error will pop-up.
Any suggestion is appreciated. Thanks.
Old Sep 19, 2016 | 12:15 AM
nocom's Avatar
My Ride: E60 525i
Hi,
I had to replace my entire transmission because the sensor that's defective is part of the mechatronic.
But yours doesn't seem to be as bad (e.g. error pops up even when car is off). You could try replacing the shifter assembly?
Good luck!
navtool.com
Test Forum
Oct 23, 2017 01:32 PM
1BFL
Sep 28, 2015 11:10 AM
Gadamsm5
E60 M5 Discussion
Sep 15, 2015 11:43 AM
ZeZe
Oct 15, 2003 12:58 PM
coops
Oct 7, 2003 04:45 AM
