Transmission diag
My Ride: 530i
Engine: M54
It's nothing fancy, just a series of radio buttons that are shown 'open' or 'shaded' based on which solenoids are open or closed.
My Ride: 530i
Engine: M54
pcy, per your request:
with INPA open and car running...
-press F6 to select 'E60'
-select 'transmission' from the menu
-double click on 'Gearbox Control Module GS19'
-press F5 'Read Status'
-press F3 'Solenoid Valve'
That will get you to a screen where you can monitor solenoid operation as you drive. FYI, for monitoring transmission temperature just press 'F7 Analog Values' instead of F3 for the last step in the above process.
Vman33
03-14-2022 04:43 AM
