Tranny problem on e60 530i n52
Hi guys, i guess you must have been bored with this topic, but i want to share with you guys my problem...
I bought e60 530i m54 engine, had transmission clutch slip, replaced the clutch, error sign came on idrive, computer said to replace the mechatronics, feeling jerkiness on upshift from 2-3 and 4-5 gears, and N to R is a bit slow, so, i Bought solenoids kits from m-scope malaysia, had them replaced, and new problem arrised, N to D is jumpy, downshift from 3-2 and 2-1 is very harsed. Replaced the valve body, N to D is still jumpy (sometimes) downshift from 3-2 and 2-1 has gotten better. Fed up with the car, sold it off N traded with e60 530i N52 engine from the same year. While testing, everything seems fine, tranny is shifting smoothly. A couple of days later, felt the car is lurching forward while coming to a stop, upshifting is normal, N to D is normal, abit slow changing from D to R, maybe about 3 sec. R to P is abit rough. And when i was cruising at about 80-90 kph, and i floored the car, the tranny downshift maybe from 6-5 or 5-4 with quite a slam...:angry::cry: If just driving it normally, the upshift is fine, its just the downshift when coming to a stop thats not so good... tranny oil was replaced In november by the previous owner, and seal adaptors are replaced too, however, the amount of money he paid to get the tranny oil replaced is seemed too cheap and makes me wonder what kind of oil and how much oil was put into it (the cost of changing tranny oil was only +/- 175usd) and in my previous e60 i spent almost 400usd to change the oil.:huh: according my trusted mechanic suggestion, is we flushed the tranny again and put new oil (400usd) and reset the adaptation... Im really frustrated...spend a lot of money to repair the first car, i dont want to spend that much money again to repair the 2nd car...i love bmws, i think its a great car...but this problem is really putting me down. It seems to me like this is heading to another mechatronic/valvebody/solenoids problem again. What do you guys think? I havent tried the pedals reset yet. Doubt its gonna have any difference. Btw my M54 was 44.000miles and N52 had 53.000miles both from 2005, so i think its 6HP19 tranny.. Any comments and suggestions are most welcomed. |
Pedal reset will not help so don't even bother.
As your mechanic suggested, replace the oil with the approved type, refill according to ZF procedure and reset transmission adaptation. This help solve my trans issue which was very similar to yours; hard down shift only from 3-2. Good luck |
Originally Posted by e6t.lab.rat
(Post 1527255)
As your mechanic suggested, replace the oil with the approved type, refill according to ZF procedure and reset transmission adaptation. This help solve my trans issue which was very similar to yours; hard down shift only from 3-2. Good luck According to prev owner, he replaced it with zf oil type 6...according to my mech, the price he paid was usually the price of zf oil type 5 and usually he used for 6hp is type 7? I dont know if this is true or not...and the prev owner replaced about 7 litres, i think usually complete tranny flush needed about 12-15litres? |
6HP19 transmissions require ZF Lifeguard Fluid 6 and approximately 7 to 8 liters per oil change. You won't be able to completely remove all the old oil with the first change but, doing a second drain and refill will be close to a complete flush.
Originally Posted by Xklusiv
(Post 1527253)
and makes me wonder what kind of oil and how much oil was put into it (the cost of changing tranny oil was only +/- 175usd) ... |
I see...will try it first...hopefully it corrects the problem...
Recent update
The previous oil change in november by previous owner was a dodgy job..oil was black and dirty. Flushed the tranny with new oil and reset adaptation only help with the bang downshift at high gear (kickdown), tranny still lurch forward when coming to a stop. Upshift still quite smooth, when changing from N to R and D to R still have a delay for about 3 seconds before the reverse gear enganged. Any ideas guys? |
i have almost same problem..
i change the fluid and still have like a "metal bang right under the center console.under the car" when i press hard the gas pedal .esspecialy from 5-6. gears lets say i cruise in D at 80mph at 2800rpm(6th gear)..then..if i have to pass fast i punch the gas pedal..and the car goes in 5th gear ,raise to lets say 6krpm..and then in 1 second change to 6th gear and goes back in 5th(this happen also on DS and on M5-M6)..:((( WHAT THIS CAN BE??? i think the only answer for our problems only DEALER CAN answer..witch will cost us $$$ good luck..:) |
(Post 1527255)
As your mechanic suggested, replace the oil with the approved type, refill according to ZF procedure and reset transmission adaptation. This help solve my trans issue which was very similar to yours; hard down shift only from 3-2. Good luck x2 - I recently got a 2007 525i and had a transmission malfunction which was throwing it into limp mode. Took it to a really great BMW only shop and they verified there was enough fluid, reset the transmission adaptations and cleared the fault (want to was was shifting from 3-2 as well). They drove it and couldn't recreate the issue. Knock on wood I haven't had any issues after 11k miles or so. Also as e6t lab rat mentioned the pedal reset will do nothing for the trans adaptations since they are separate 'learned' values to the car's computer |
Originally Posted by stel_i79
(Post 1527512)
i change the fluid and still have like a "metal bang right under the center console.under the car" when i press hard the gas pedal .esspecialy from 5-6. gears lets say i cruise in D at 80mph at 2800rpm(6th gear)..then..if i have to pass fast i punch the gas pedal..and the car goes in 5th gear ,raise to lets say 6krpm..and then in 1 second change to 6th gear and goes back in 5th(this happen also on DS and on M5-M6)..:((( WHAT THIS CAN BE??? i think the only answer for our problems only DEALER CAN answer..witch will cost us $$$ good luck..:) The problem is that in my country its not easy to get the parts to do this repair...usually they just change the whole valvebody assy.... |
| All times are GMT -8. The time now is 04:53 AM. |
