Tranny leak fixed under CPO last week a day before it expired, tranny
Old Apr 13, 2010 | 11:35 PM
Wanderlei's Avatar
My Ride: 04 545i
3 months ago my 04 545 had a tranny leak discovered by a third party shop during a multiple point inspection, the CPO covered the trans pan seal change. A week and a half ago i take it in again because my transmission started jerking on low gears. Sure enough they found a "major tranny oil leak", they replace the Tranny sleeve connector and pan gasket. Leak still found on "wrap oil pan"(?), they replace the complete pan and leak disappeared. Luckily I had 2 days before my CPO expired.
NOW A WEEK LATER and my tranny is jekry again, especially at 35-40mph. I am taking it in on Thursday but my CPO is now expired. What is the likelyhood they fix it?
I am now concerned it could be major tranny problems and is going to cost an a$$ load. If my tranny needs major work could I make case to hold them liable?
Thanks for any thoughts
Old Apr 14, 2010 | 12:37 AM
protams's Avatar
My Ride: 530iA 04
Did they add oil in gearbox after repair?
Old Apr 14, 2010 | 12:54 AM
NC916's Avatar
My Ride: 05 530I
I'm pretty sure they should fix it still even though your warranty is expired because the fixed it twice under warranty and still having problems. I would call the NA if they want you to pay it, it might be still covered.
Old Apr 14, 2010 | 10:26 AM
Wanderlei's Avatar
My Ride: 04 545i
I sure hope so!
Old Apr 14, 2010 | 10:58 AM
skelevirus's Avatar
Model Year: 2019
I sure hope so!
Old Apr 14, 2010 | 11:21 AM
ivan545's Avatar
I had the same problem with 545i, I have the megasleeve replaced because it was leaking, and that was done at 69,990 miles and now at 91k my tranny leaked again. They have the vacuum pump replaced, anybody know is that internal or external of the tranny, but it does not state they added fluid. I'm calling Bmw NA now because I also have some questions and concern about warranty.
Old Apr 14, 2010 | 07:23 PM
ivan545's Avatar
I did a search on the Real Oem parts and found out that the vacuum pump is what the dealer replaced for my oil leak.
Tranny leak but replaced vacuum pump they said it was a source for leak.
Tranny leak fixed under CPO last week a day before it expired, tranny -187.png
Awest91
Sep 17, 2022 11:05 PM
Kasmo
May 7, 2019 03:30 AM
TexaZ3
May 6, 2015 09:54 AM
545iBMW
Apr 28, 2015 03:24 AM
andrek
Mar 26, 2015 08:00 AM
