Tranny Issue - Mechatronics?
My Ride: 530i
Engine: M54
You're welcome. If you need any pointers, etc post here or feel free to PM me. sounds like you have worn out solenoids just like the rest of us. if you do end up replacing them make sure you replace the bridge seal and four sealing sleeves that sit between the Mechatronic and the transmission casing, they're very important!
My Ride: 07 E60
My money is on low fluid level or incorrect fluid type replacement.
That is if and only if...... the symptoms are new since the pan change.
Maybe if that transmission is excessively crapped up on the inside and sediment was loosened during the pan change will a drastic change occur. Unlikely as the OP would have noticed prior issues.
My Ride: 545i
Engine: N62
At this point, I can't really rule any of these suggestions out. I'll start with the easiest solution and work my way up.
I never had any issues prior to the drain. I did not even have issues directly after the drain. I would say this started a few weeks back. That is why I am leaning more towards the solenoids. Can't hurt to drain / refill. I'll get more of the original fluid out I guess. I would just hate to drain / refill to find the same issue.
My Ride: 530i
Engine: M54
Have to disagree with you here Kyle.
My Ride: 545i
Engine: N62
So the fluid appears to be fine. So leaning towards the solenoids. How many hours does this take to replace? I am trying to find someone to do the work. I got quoted 8 hours labor form an indy. Pretty sure that is way too long. Any ideas?
My Ride: 530i
Engine: M54
Good luck, hope it works out for you.
My Ride: 545i
Engine: N62
Ok, so a funny thing I noticed. I did the accelerator reset (hold for 30 seconds) as I normally do every so often. The issue is not happening. I know this is only temporary, but why would this be the case? If the solenoids were bad wouldn't this happen regardless of this reset?
My Ride: 530i
Engine: M54
Are you at the point where you're actually getting transmission fault codes stored in the TCM and/or getting the dreaded iDrive messages? Once it gets to that point you either address it immediately or you will be buying a transmission. Sounds like you're not at that point yet.
Do yourself a favor and replace the whole mechatronic's. I went through this with my 05 545i Get everything from Klaus new pan -filter assembly, case of fluid and the unit. Wish you were closer to Boston I would do it for you. Took me six hours to do mine.
