Traction Control Light Blinking
My Ride: 2007 525 XI
1968 AMC AMX
Got a question about my traction control.
Just bought a 2007 525 XI. I took it around an on ramp, on dry pavement and the traction light started flashing/blinking and felt the brakes doing their thing. Now I wasn't pushing it real hard, but certainly harder then my wife would.
I took it back and BMW replaced some traction control sensor. This morning it did the same thing.
So the question is, is this normal for a XI?
Thanks,
Jeff
Thanks,
Jeff
They must have got an error code from the sensor if they changed it. So, I don't know how hard you pushed it, but if you think that traction control still operates when it shouldn't, I would check the cable coming from the ABS/traction control sensor. Once I got an error code about a faulty sensor, but the true reason was that the cable coming from the sensor was damaged inside the car, in a trunk.
- Antti -
- Antti -
I don't have an xDrive, but wondering if all four of your tires are identical? I can imagine that if one or more are not identical in circumference, then the DTC might be triggered even in moderate cornering. Just a guess.
But, it's probably a sensor or wire connection, like previously speculated.
1968 AMC AMX
To give you an idea as to my "pushing it", this is a turn I would typically go 45 to 50 in my old 528. In the 525 I get to 38 and the traction control kicks in.
I checked the tires and they are all the same, but good thought.
I'll take it back and tell them to take another look at it.
Thanks for the relies.
Jeff
Jeff
DavaiLave
Aug 2, 2022 02:16 AM
TexaZ3
May 6, 2015 09:54 AM
andrek
Apr 4, 2015 08:47 AM
