TPMS replacement?
Old Feb 23, 2010 | 01:54 PM
nikko64's Avatar
My Ride: 2011 550i M sport
Hello all. I will be needing to replace my tires on my 2005 545i. I have the TPMS system. Do I need to replace the sensors as well?
Old Feb 23, 2010 | 02:36 PM
EBMCS03's Avatar
You mean tire pressure sensors? No your system uses the ABS sensors to monitor for a flat so theres nothing for you to worry about.
I rather like that system more. less costly to swap tires around.
Old Feb 23, 2010 | 04:19 PM
SilberGrauE60's Avatar
I think if you check in your iDrive (open the i menu, then Vehicle Settings) you will see FTM (Flat Tire Monitor). This system does not use air pressure sensors like TPMS, rather uses wheel speed as has already been mentioned.
There is no hardware to replace when replacing tires, but you will need to re-initialize the system after setting new tires to proper pressure. You will need to follow the instructions on the FTM page in iDrive.
Basically, you click "Set tire pressure" while stopped with engine running, then drive off. The status will show "initializing" until it recalibrates while moving, then change to Active. Just keep driving until the system shows active.
Old Feb 25, 2010 | 07:42 AM
SmG-Deuce's Avatar
My Ride: 05 545i | sliver grey metallic | SMG trans | sports package | premium | cold weather | HUD | navi | PDC | sunshades | logic 7 | Ipod | MODS - (Mtech v2 angels )(8000k headlights and fogs)( Full Xenon kit) (///M shifter) (LCI u.s spec tails) (285/30/20 & 255/30/20 beyern baroque 3pc rims) 03 FX45 AWD | silver| sports package| premium package| (WIFE) (sold)06 330i | cherry red | sports package| premium | cold weather | logic 7 | Ipod | ( WIFE )
that system saves us money and its pretty cool....i was wondering would i get a error code when i put my 20s on this spring but this answered my question
Old Feb 25, 2010 | 11:11 AM
EBMCS03's Avatar
You shouldnt have any problems, it uses rotational speed of each wheel measured against each axle so as long as its initialized correctly it'll work. I dont like the new system cuz it doenst tell me the "exact" tire pressure and it costs me extra $150 for a place to swap out the sensor and re balance all my wheels.
550iWade
Feb 22, 2017 04:21 AM
coreybunz
May 1, 2015 07:24 AM
cakes
Apr 14, 2015 04:50 PM
BrandonSS
Mar 30, 2015 09:48 AM
sportzfan76
Mar 30, 2015 07:19 AM
