TPMS
My Ride: Current: 08' white 535i premium package
Mods: Dinan aluminum pedals
LED Rear license plate lights
Future Mods: M-tech bodykit
OEM 167 Rims
Past: 06' metallic black 525xi premium and sport package
Hey guys, I'm sure that this came up before, but I'm gonna ask anyways.
I'm so lost. Previously I had a 06' 525xi and now I have a 08' 535i.
Today, I got the winter tires/wheels that I used for my 06' 525xi put on the 08' 535i.
The TMPS warning light came on so I tried reseting it but didn't work.
The wheels that i'm using are non-OEM.
What should I do to get rid of the warning msg?
Thanks
Thanks
Are you sure the winter wheels have TPMS in them??? Is your valve stem rubber or metal? Metal indicates TPMS.
My Ride: 2005 BMW 525i A/T (E60)
2005 MBenz C200K Elegance
2004 BMW 320D A/T Exclusive (E46 F/L)
2003 MBenz C180K
2001 BMW 318i (E46)
What the TPMS does, is compare the rotational speed of all four tyres, and should one of them rotate at a different speed than the others (as would be the case in a flat tyre), it gives you a warning. You do not mention what size tyres you have on what wheels, but I can only assume that there might be a difference in size between the four tyres, which could also trigger the TPMS warning system (different size, different rotational speed).
Can you perhaps post what tyre sizes you have on what wheels, and whether they are all four of a equal brand name?
Originally Posted by DrLev99' post='702012' date='Oct 24 2008, 03:50 AM
You are describing FTM, not TPMS. TPMS consists of actual monitors inside each wheel, unlike FTM which works via the above method.
I had a low tire pressure warning yesterday morning. The RF tire was "yellow"
I added air and the RF tire went to "green" on the idrive display.
My Ride: 535XIT Space Gray, Cream Beige LeatherCold Weather, Premium, Auto, Rear Side Window Shapes, Heated Rear Seats, Park Distance, Navigation, Satellite Radio
Model Year: 08
Originally Posted by roadie' post='702078' date='Oct 24 2008, 06:56 AM
That is correct.
WARNING! Tire Pressure Monitoring System
Your vehicle is equipped with a tire pressure monitoring system that requires a sensor to be installed in the tire and wheel assembly for proper operation.
The original sensors from your original wheels can be used or you may purchase sensors from Tire Rack.
Your system includes:
433MHZ TIRE PRESSURE SENSOR
$168.00 for a quantity of 4
REQUIRED VALVE
$32.00 for a quantity of 4
Total Price: $200.00
http://www.tirerack.com
Or check with your dealer if there is a way to disable the monitoring.
Model Year: 08
2003 MBenz C180K
2001 BMW 318i (E46)
For instance, FTM is called TPM (Tyre Pressure Monitor) here.
As stated before you can:
Buy TPMS for your winter set-up (tirerack.com)
Live with the error message all winter
Possibly have your dealer disable the tpm function (not sure if that's possible in the US)
You could also just have your TPM's from your summer wheels put into your winter wheels.
GL, Gene
GL, Gene
