TPM Sensor Problem on 20" Maya STM
hey guys, i tried looking through the forums but couldn't find anything on this. i just installed 20" Maya STM's on my 2008 528i but the place i took the wheels to get mounted and balanced couldn't fit the TPM sensors on. now the TPM warning indicator is always on. is there a way to turn off the TPM all together or is there some kind of an adapter that i can install to get the TPM sensors to fit on the Maya's?
There are two ways of installing the TPM on the wheel.
1. If Maya drills a hole in the inner barrel of the wheel, simply have the TPM installed in the hole.
2. If there is no hole, the TPM can be fastened using a steel strap.
If you are in SoCal, I can refer you to a source.
Rishi
Rishi
My Ride: Fully Loaded Monaco Blue 550i Sport
Honestly if a tire shop cant retrofit your tire pressure sensor on the new wheels then you shouldn't be installing your wheels there... its pretty simple.
I would go with the drilled hole approach.
If done correctly, there should be no marks, just a bigger hole. The sensors and valves will fit nicely into the bigger hole.
I have heard of good results with the strapped sensors, but make sure that the installer has done this before.
The concept of a sensor breaking loose while traveling 80 mph is frightening.
Best regards,
Richard
Best regards,
Richard
My Ride: 2007 E60 530i
Color: Jet Black/Black Anthracite
STEP | Sport | Premium | NAV | Logic 7
EXTERIOR:
M-Tech Kit | M5 Mirrors, Trunk Finisher | Jet Black Kidney Surrounds | Madico Charcool Tint 54%, 35%
LIGHTING:
Euro-Headlights | Euro-LCI Tail Lights | AiB V3.0 | Solaris Invisi-bulbs | OEM LED Plate Lights
PERFORMANCE:
Porterfield R4-S Brake Pads | K&N Air Filter
WHEELS & SUSPENSION:
Work VS-XX 20x9, 20x10 | Toyo T1R 245/30/20, Michelin Pilot Sport A/S 295/25/20 | KW V2 Coilovers | Rogue Engineering 15mm Spacers
I would try to avoid drilling into the inner barrel if possible. This can sometimes cause a slow leak because the TPMS does not always sit flush on top the barrel. Have your installer use these instead: http://forums.e60.net/index.php?showtopic=44723&hl=
And I agree with NY550i, if your shop can't retrofit something as simple as TPMS, get the hell out of there and take your business somewhere else!
