TPM problem
My Ride: 2008 535i Sport
ever since i got my user 530, tire pressure light keeps going off about once a week and the pressure is fine in all wheels. The car is at the dealer for the third time and i got a call from them saying that they will be replacing a DSC module, which might be related to the problem. They also mentioned that tire tread varies between 4mm and 8mm and that could also cause the light to go off? i find that hard to believe. It seems like they are still not sure what's going on. But i hope replacing that module will fix the problem. Anyone here had the same issue? any help is appreciated.
Well, got my car back today. They also programmed the car with progman version 29.1.1. The comments are showing tire tread at 4, 5, 6 and 8mm and they said that they recommend them to be replaced. I did speak to the SA about this, told him i bought the car 2 months ago and it was CPO. He said if the problem comes back, then it's for sure related to the tires, and he might be able to make a case out of it and maybe replace the tires.
My Ride: 2004 525i, Titanium Silver, Gray Leather, Premium Package, Steptronic trans, xenon adaptive headlights, sat. prep, no navigation, bluetooth, ipod adapter
well, it turns out that one of the tires did get replaced right before I bought the car. So, most likely that's what it is. In this case, I am anticipating the light to come back.
Well, it's been 3 weeks and well over 1000 miles since the fix, no FTM light. Looks like it's fixed thise time. SO, if somene does have the same problem out there, most likely it's the DSC module.
BrandonSS
03-30-2015 09:48 AM
