TPM Malfunction - advice.
#21
My Ride: 05 bmw 525i
Only thing in the spare foam is the micro power module an that has a little water residue inside of unless I have to change that. Or do you know if I have a ftm box or module and if yes where is it located?
#22
I believe the FTM monitoring is part of the DSC system and is integrated into the DSC module.
#23
Ok thank you I think I found the problem I checked both of my rear wheels the abs is intact but the next cable I think that's deal with the rdc or tyre monitoring is missing or have been pulled out one side has it but the rear left side is missing the cable I don't know what it name but it goes into a black box an has a white connection it has been pulled out
#24
#25
Don't think so. There is an ABS sensor on each wheel. But, there is only one brake pad sensor in the rear and the other rear wheel does not have a brake pad sensor. Same for the front -- only one. That would explain why there are two wires on one side and one on the other.
#26
Ok so what would be causing the rdc error and a3c3 code
#27
Don't know. Tell me more. Did you just get the car? Was the error always there? Did it just come up? What happened around the time it came up? How did you go about retrieving this code a3c3? Have you read all the codes and are there other codes? Could the car have some replacement electronic parts that came from other cars?
#28
Okay the car was hit on the rear right side and and ever since then it was giving me that error and I got the codes from inpa, and no there are no replacement parts that I can recall. Other codes I got was 5f62 a050 dad a3c3 a43e
#29
Have you checked all the fuses? On my 2006, a lot of them live on the right side behind the trunk liner.
A43E is the KGM module. see this: KBM60 - Bavarian Technic
Post the INPA screenshots of the other codes.
#30
I am trying to upload the inpa pics but I keep getting an security token from the site.
But these are the errors
01 sim/sgm 93fc 93cc 93cd
12 DME/DDE CDA7 CDA9
16 AFS 6140 6145 Ce93
29 DSC 5F62
40 CAS A0B0
60 Kombi A3C3
72 KBM A43E
29 DSC 5F62
40 CAS A0B0
60 Kombi A3C3
72 KBM A43E
