TPM malfunction
#21
While I agree that 5 to 7 years is the expected life span I have a GM vehicle going on 11 years with the original sensors with no issues. It also uses Beru sensors (same brand that BMW uses). I guess this is sort of like car batteries. Sometimes you get a really good one and other times you don't. I would imagine climate has something to do with it too. Extreme hot and cold takes a toll on batteries.
You can thank our government for trying to protect us from ourselves. I think the Firestone issue on the Ford Explorers had a lot to do with this. I guess on the plus side this might protect us from some other idiot that never checks his tire pressure causing a massive accident taking out innocent lives.
In the "old days" it was kinda easy to spot (by eye) when your tires were low or not properly inflated.
However, proper tire pressure for low profile tires and (especially) Run Flats isn't as easily "seen by eye" so typically the sensors are designed to trigger a differential of 5-7PSI from the preset pressure. Sometimes that drop can occur during season changes and a drop of 30-40 degrees in ambient temperature ... letting the driver know their tire pressures should be checked and adjusted.
SO, if you don't check your tire pressures regularly, never collect a nail, or crack a wheel ... think of TPMS as a friendly reminder
![Heart](https://5series.net/forums/images/smilies/imported/heart.png)
#22
Come on guys read the entire post and ask the right questions lol
OP - Is that a photo of your car listed above? Do you have TPMS or FTM? What is the build date and model of your car? - That will be most helpful before you go out and purchase anything. I say this only because if you do have TPMS then you swapped wheels without checking to see if the TPMS can be fitted to the wheel you chose. If you do have TPMS where are your old sensors? Still in the OEM wheel?
Yes,that is my car, like I said before,I don't know much about cars.I know how to drive & which ones are nice,that's pretty much it.That's why I come on sites like this,I learn stuff from people who know more than I.
#23
Ok, so it looks like you have an LCI from the front headlight corner but I can't tell so if you give a month/yr built then we can be more helpful. Another canadian mentioned that in canada 08 5 series only had TPMS. While I find that hard to believe, It can be possible. I would think that canadian cars are part of the north america market but probably discrepancies there too. BMW is complicating that way.
Metal valve stems usually do indicate that you have TPMS. However, I have a whole box of metal valve stems and I don't have TPMS. I like metal valve stems better personally. But chances are if you have an OEM wheel with run flats and metal stems then you have TPMS and the sensors are under that tire.
