TPM is completely grayed out in the info centre
My Ride: BMW 525I
Hey guys
Today I tried to reset the TPM, but when I go to the info centre on the iDRIVE it's completely grayed out and doesn't let me click on it at all.
Does any of you know what the problem is?
Thanksss
Thanksss
If you already clicked on "reset", it will stay greyed-out until you drive the car and the reset completes.
My Ride: 2005 525i 6MT
My Ride: BMW 525I
I've tried everything u guys said but it's still greyed out. Would there be a problem with the TPM module? Since I've read in many placd that it's a common problem
Which type of TPM do you have?
I have a 2006 530xi and it is the last of the non-direct reading TPM types. It cannot tell the tire pressure, it uses the ABS sensors to tell how many revolutions the tires are making and if there is a difference it complains. The idea is that an flat or under-inflated tire will have a different revolutions/mile compared to the other tires. Later models have a direct pressure reading sensor mounted in each tire.
jeffandjaimie
07-08-2015 05:48 PM
BurtonSnol3order
07-03-2015 09:28 PM
