TPM changed to FTM!?
Hey gents, I recently coded my car with NCS. ( 09 535i ) Today i changed tires, went to reset the TPM and it now says FTM (which I know it's used in other cars) but it is grayed out i cannot reset it. I'm using NCS and coded most of the options for the e60, what could have caused this? Thank you in advanced.
My Ride: 2008 528xi (Silver)
I had a TPMS error and didnt need TPMS, so i coded them out with NCS. Maybe something you did in your coding removed TPMS from you VO. Add it back and you should be good. Believe it is $2VB
edit: I loaded the NCS expert profile and reset the CAPPL module, that got me the TPM back and the FTM is gone, now the problem is... still grayed out and won't let me reset!!! I did change the VO too but that didn't work, so I added the $2VB back just in case... I'm stuck now.
edit: Turned off the car for about 30 minutes, restarted it and TPM was enabled again. Had to re-code the car but it's all good now. Thanks.
