tires losing traction !!!
My Ride: 2004 BMW 545i Sport Package, Titanium Gray II Metallic, Wheel Style 124
Originally Posted by EBMCS03' post='884379' date='May 20 2009, 09:06 AM
Ah there you go... with off brands, the tire compound might not have been developed and tested to stand up to heat and cold as well. Many times, you pay for what you get.
time to research tires suggestions from forum
![Happy](https://5series.net/forums/images/smilies/imported/happy.gif)
My Ride: 2005 545i SMG
Nexen is actually a fairly reputable brand established more than 30 years ago.
I am actually on 3rd set of Nexen N3000 and I can tell you it's a great tire.
And I live by far worse weather conditions than OP live in.
My winter temp goes as low as low 20s and as high as 115+ during the summer.
I don't see how could a tire or in this case tires to be problems after 15k miles of trouble free miles.
Tires are usually defect from the beginning or within first 1000 miles.
There are always degradation gradually but not like this all of sudden.
And tire pressure won't give you that much dramatic difference like skidding across lane.
I smell a possible suspension failure/worn out. By the way OP is describing the situation, it has to be
other than tires.
Researching away on tires at the moment... i am looking at Falken 452 & Toyo T1R
by the way when i press down on my front right shock or suspension it seems to squeak and it's fairly soft the left side has same tension with no squeak the rear are stiff i cant hardly press them down
Again, I'm just trying to say the way you describe it, it can't be tires alone.
look at this... Rear tire is bald from the inside
![](https://img188.imageshack.us/img188/3393/photokxe.jpg)
i placed a order for Falken, i will goto dealer this week i feel suspension is soft i feel all the bumps and cracks on the road
![Embarrassment](https://5series.net/forums/images/smilies/imported/ohmy.gif)
Originally Posted by uheenada' post='884401' date='May 20 2009, 09:29 AM
I disagree with this.
other than tires.
other than tires.
I highly doubt that. It doesnt matter that nexen has been around 30+ years. I can name tons of companies that have been around longer and yet they still somehow produce sub par quality products.
I would guess it would be the tires since he likes to drive a bit aggressive. Thats where I would start after checking all the suspension parts.
Nexen is an OK street tire, nothing special and certainly not a huge performer if youve ever had high performance tires like Pzero Nero, S-03, Invo, PS2 Pzero Rosso
i placed a order for Falken, i will goto dealer this week i feel suspension is soft i feel all the bumps and cracks on the road![Roll Eyes (Sarcastic)](https://5series.net/forums/images/smilies/imported/rolleyes.gif)
My Ride: E60 530d M-Sport
That indeed does not look like its in good shape.......that looks like one of the rear tyres which came off my old E46 with KW, the rear camber was way off on that car afterwards and made my tyres look just like that, the car was excessively low however which caused the geometry to go way out.
Originally Posted by PraiseTheLowered' post='884915' date='May 20 2009, 05:47 PM
yeah check camber to make sure
bmw oem spec is -2 degrees
if you run more than that you will need a really good street tire that holds up
nitto invo man
nitto invo man
