TIRE SIZE
Originally Posted by katheikia' post='211235' date='Dec 14 2005, 03:18 PM
So basically when I replace my run-flats use the same exact size, width as the original?
225/50/17
225 = width of the tire in mm's
50 - ratio of the sidewall to width
17 - rim diameter
you can not change the rim diameter - only 17's will go on 17's
The problem is that rims are measured in inches (17 x 8), etc - and width is measured in mm's
so it is possible to change the width of the tire to narrower or wider and stay with the same rim - most rim muanfacturers will have a range of widths that will fit
My Ride: 2015 535D M Sport
Originally Posted by katheikia' post='210866' date='Dec 13 2005, 06:34 PM
I have a 550 with sport package (18" rims) Can I put a 19" tire without getting new rims?
Go here http://www.miata.net/garage/tirecalcold.html to see what you can & can't do.
You also could go to here: http://www.tirerack.com/tires/tiretech/tec...¤tpage=46 to get some additional information.
You probably should just call Tire Rack and they will tell you what tire sizes you can put on your current rims or what size new rims & tires you can fit on your car without screwing things up.
You also could go to here: http://www.tirerack.com/tires/tiretech/tec...?tpage=46 to get some additional information.
[/quote]
Good info especially the first link.
Regarding the topic the answer is no. I also thought about putting 255 tires on my back, knowing that i have the 135M rims with 245/40 R18 both F/B. As you can see it can't be done, not without messing with the spedometer reading and maybe even the stability of the car. The best way i presume is to change the rims to 19's and with the oem setup (245/35 R19 F and 275/30 R19
![Cool](https://5series.net/forums/images/smilies/imported/cool.gif)
asinner
05-06-2015 06:03 PM
HS_01
07-05-2004 06:15 PM
