Tire Question
Old 07-07-2009, 07:53 AM
khooger's Avatar
You guys did mention that 285/30/19 can fit in the back on my BBS RS GT's.....I know the recommended size is 275/30/19.
think fender roll will be needed???
Old 07-07-2009, 08:18 AM
DrLev99's Avatar
What's the rear offset again? If it's ET20 or higher the 285's should work with no rolling.
Old 07-07-2009, 08:19 AM
JAY'545's Avatar
I have 285/30s in the rear and have no rubbingno fender roll.
Old 07-07-2009, 08:21 AM
TEAM M's Avatar
ur fine I got 285/30/20 in the rear and there fine no rubbing at all make sure you got the right offset thats most important if you don't want rubbing and vibration. GL
Old 07-07-2009, 08:44 AM
khooger's Avatar
Yes its 25mm offset on the rear......
Old 07-07-2009, 08:52 AM
DrLev99's Avatar
You are good to go. MRFVA and DRANGED are running 285's with ET20 on the rear with no problems, so you'll be fine.
Old 07-07-2009, 09:05 AM
khooger's Avatar
Thanks...you have been a super help
Nihilation
07-10-2022 11:32 AM
windnsea
05-25-2015 09:49 PM
SNYPRUSMC
04-28-2015 04:14 PM
srogers535x
14
04-26-2015 09:39 AM
brian1225
04-16-2004 05:59 AM
Quick Reply: Tire Question
