Tire Monitor Question
My Ride: 2004 545i 6spd Man, 19' Breyton Wheels, Ipod Install, Parrot Bluetooth, AC roof and Trunk Spoiler
Originally Posted by bauska530i' post='510662' date='Dec 26 2007, 09:18 AM
You can also tell by the tire valves. If it is a rubber one - no special equipment, FTM thru iDrive. Check the pressure in all tires and you will see which is low. I just went through this....I had a screw in my run-flat, but all tires seemed ok; however, the pressure in one tire was zero. As mentioned above, afterwards make sure you reset the FTM in i-Drive.
My Ride: E90 M3
Model Year: 2011
Originally Posted by rudeja' post='510733' date='Dec 26 2007, 12:10 PM
I put some Air in the tires but I dont know how to reset the light, I dont keep the manual in the car, so I guess i have some reading to do when i get home.
Originally Posted by kscarrol' post='510735' date='Dec 26 2007, 01:17 PM
Reset = With the car running and in Park, press iDrive knob down to get to car menu. There you will see an option like Vehicle/Tires. Scroll to that and press the iDrive knob. You will see FTM, select that and there you will see the Reset option. Once you do this the iDrive will say Initializing. You must then drive the car for a while for the system to reset. Best to use a long stretch of open road rather than stop and go traffic. Do it before you leave for your drive home, should be done by the time you get there...
My Ride: E90 M3
Model Year: 2011
Originally Posted by rudeja' post='510743' date='Dec 26 2007, 01:01 PM
Thank You, I have a 3 mile commute from work, hope thats enough
My Ride: G30 M550i
Model Year: 2018
Originally Posted by kscarrol' post='510751' date='Dec 26 2007, 02:34 PM
It should be fine but I have had mine take 10 minutes or more to reset, so be patient!
My Ride: E90 M3
Model Year: 2011
Originally Posted by CTYankee' post='511143' date='Dec 27 2007, 04:43 PM
Would you happen to know how to reset an LCI car that does not have LCI wheels? I just put snows on (they were from my 06 530--on wheels--in good condition). FTM now will not initialize--I assume because the old wheels don't have the sensors that the new wheels do. I'd just as soon deactivate FTM for the season. I'm an old fashioned guy--I check my tire pressure once a month with a gauge (remember them?). Do you think that's possible?
Originally Posted by kscarrol' post='511150' date='Dec 27 2007, 05:56 PM
Never seen this in a car, are you getting a warning message or is it just that the system won't initialize?
If there's no way to deactivate the system I'll have to get the dealer to install the sensors. Thanks for the info.
My Ride: E46 330, E60 550 on order: Carbon Black/Natural Brown, 6MT.
Originally Posted by CTYankee' post='511163' date='Dec 27 2007, 06:19 PM
I'm getting a warning message: TPM Malfunction!
A set of sensors will cost about $170, plus the cost to remount the tires. This may save you a few bucks.
